Results 1 to 10 of 11
Thread: cutting out again :@
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Default cutting out again :@
    right she has started cutting out again the egr has been replaced and injectors 2 and 3 have been refurbished as they came up with that fault last time she was cutting out. drove for 2 hours before it started missing and juddering at about 2000rpm and the eml light would flash on and off until it cut out. i then turned it off and on again and it would drive again. got towed home in the end. the faults read as injector 2 and 3 fail and 3 open circuit. i know the injectors are fine as they have been tested, what else could it be? dry joints in ecu?
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Wiring to injectors been checked? Ecu control?
    Ecu checked for latest software
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Quote Originally Posted by Critch View Post
    How do u update ecu software? I never seen anything of that anywhere
    Apr 2012
    littleport
    my mechanic has been pulling the loom apart, not heard if he has found anything. how do you change the software
    Aug 2012
    ECU or Wiring Failure? Have you traced back and checked the harness for damage? I had a car where the loom had managed to come in to contact with a pulley. It wore through the coating and eventually shorted cables and stalled the car. However I never suspected this as I could restart the car right away. What was happening though was that the engine tilted slightly forward on its mounts under load. This allowed it to come in to contact with and short the wires. Once off thought the short circuit had gone and the engine would fire up. Had me going for a while that one I can tell you!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by jamesmcuk View Post
    Apr 2012
    littleport
    hopefully he will find something like that then its a cheaper fix lol
    Apr 2012
    littleport
    suppose that what would cause the eml to flash on and off if it keeps loosing contact
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Had a similar fault on Renault Clio where engine harness securing block rubbed through harness an was shorting it out on acceleration. Causing limp mode until turned off.
    As for software update dealerships can do it.
    Otherpeople with relevant software an a vxl service box subscription can download latest update an do that way.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by smartalec0310 View Post
    Sometimes tracing wiring faults cost more than having to replace parts.
    They are time consuming unless you are very very very lucky.
  1. 1.9 150 cutting out
    By japkadett in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 21:26
  2. Cutting out
    By Chuddy in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:37
  3. my car kept cutting out??
    By Curly7 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 21:23
  4. 2.2 dti cutting out in 4th and 5th
    By j brown in forum Engine & Drivetrain
    Last Post: 12th May 2008, 20:34
  5. Cutting out!
    By Mike 3.2 GSI in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2005, 13:04
