Thread: Still occasional bang from front after replacing ARB droplinks
    Default Still occasional bang from front after replacing ARB droplinks
    Hi Guys,
    I just last week replaced the front ARB droplinks (with uprated ones) due to banging over potholes, speed bumps etc. The originals have done 93K and tbh looked shot! New ones seemed to cure the banging and car handling felt noticeably tighter. My car is a 56 SRI estate 1.9 150 btw.
    However, last night I was out in the car going down what seemed a particular bumpy road and could hear/feel an occasional knock. Again from the front. It seems to occur more often with big rolling type bumps rather than 'sharp' potholes.
    Any ideas what this could be? I'm thinking that the new droplinks may now be transferring more 'energy' into the ARB bushes (i.e. they are working harder) and if they are worn out then i'll get bangs and knocks from there. The knocking sounds the same as the knocking from the old droplinks maybe not as loud. I thought about changing the ARB bushes as a matter of course when doing the droplinks but decided against it.
    Springs are only a couple of months old. I didn't replace the top bearings or top mounts when i did the springs. The bearings seemed to be smooth and didn't appear to be dry - plenty of grease in there. I also reused the plastic sleeves around the bottom of each spring.
    Gonna try nip up the body to top mount bolts tomorrow to see if that helps. In the mean time what do you reckon...It's not the characteristic 'squelching' sound but could it be the ARB bushes??
    Finally car had MOT today. Pass with no advisories (go figure!).
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Fitting a second spring rubber base normally helps but without hearing hard to know.
    Quote Originally Posted by mattv6diesel View Post
    You mean the "sleeves" that go on the end of the springs?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Yeah mate worked wonders on all 4 of mine i got intermitant twang/ dong noise.
    Interesting. Where did you get them from Vx? I just did a couple of searches on ebay but didn't really know what to search for. Came up with nothing.
    That said (and i would be willing to try an extra set of sleeves), it does sound more like a knock or bang rather than a twang. I heard the last front spring go when reversing out of my parents drive and that was definately a TWANG...knew instantly the spring had gone.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Vx they are a couple £ but not alot. Work at vx it's a rework, so if a customer complains it's a cheap attempt to fix it. All 4 vectras i've owned made a big difference.
    Easy to find on the parts computer there is a choice of two green or blue which are different diameters
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Enclosed part no,s for the two spring sleeve sizes.
    Insulator 13178463 (for Spring Wire Diameter 11.8-12.9mm)
    Insulator 13178464 (for Spring Wire Diameter 13.0-14.0mm)
    and still loving it
  1. Replacing new front shocks. What else?
    By Marky in forum Handling & Braking
    Last Post: 20th August 2012, 15:14
  2. Front Anti-Roll Bar HD Droplinks - Torque Loading
    By wafoo in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2012, 21:18
  3. Do you have to re do the tracking after replacing droplinks?
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 23:44
  4. Front bang/knock noise on turning wheel
    By NPS in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2009, 19:58
  5. Cillit Bang,BANG,BANG...
    By kgsric in forum Comedy & Humour
    Last Post: 10th December 2007, 22:39
