Results 1 to 10 of 17
Thread: Help needed - nissan micra
    Jan 2010
    Hucknall, Nottingham
    Default Help needed - nissan micra
    Just need some ideas really. THe other half's car is overheating, but the collant level hasn't decreased so I know its not leaking. I suspect the fan is broken as it never comes on when the engine is running - but how can I test it? I suspect a multimeter in the plug would help, except I don't have one....any other ideas?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    themostat?
    sure fans dont come on very much in normal circumstances, to test fan leave it turned on the drive for a little while, but keep eye on temp gaugue to make sure you can turn it off, dont leave it unatended.
    Regular Member Phil881's Avatar
    Sep 2012
    Edinburgh
    12v supply straight onto the fan.....watch your fingers!!!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Give the fan a power an earth an serif outruns up.
    How ever really do need a multimeter to check power wiring etc.
    Basic first check would be fuses an relays
    Do the cabin heaters work correctly?
    May 2012
    northumberland
    fan may work if he just applies 12v though it could be a faulty switch that turns the fan on off ect
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    more likely the thermostat
    check the fan will turn by hand without making noise obviously make sure its not hot
    if the fan has gone then the chances are the fuse would blow id check that fuse first
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    usually disconnect plug from temp sender and bridge the two wires and fan should come on this should show if temp sensor is faulty-
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    It could be the stat for the fan and not the fan itself. That stat is usually in the rad somewhere with 2 wires to it. Normally the stat just earths the fan when up to temp but may be different on a micra. Just try linking it out and see if the fan kicks in.
    May 2012
    northumberland
    will say that my old nissan primera 1.8 was and still is the most reliable car i have ever owned, once ve had this vectra for 2 years ill be in better position to say if that was still the case.
    May 2012
    northumberland
    yes, thats why i think just shoving 12v to the fan would only proove if the fan motor was working, i cant see it been just the fan, but id like to be prooved wrong.
  1. M reg Nissan Micra
    By ade0303 in forum Cars for sale
    Last Post: 2nd June 2009, 23:49
  2. burned up a nissan micra!
    By izonoky in forum General Chat
    Last Post: 27th March 2008, 21:59
  3. Help! - with a micra
    By lborob17 in forum General Chat
    Last Post: 11th November 2005, 21:29
