Thread: What con rod for 2.0 dti?
    Mar 2011
    wigan
    Default What con rod for 2.0 dti?
    I have bent a rod on my 2.0 dti (second from left) and am looking for a second hand replacement. I've seen many on eBay advertised y20dth vectra, Astra, zafira etc but they all have 4 valve seats on the piston that's attached to it and say there for a 16 valve. My engine is an 8 valve but the same engine code. Will it fit? Ta
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    It should fit.
    But you could always knock pin out an literally swap con rod an use your piston
    That way should still be ok as wear to bore an rings should match still
    Mar 2011
    wigan
    Yeah I'm using my original piston it's just how they seem to be sold. I can't find one that doesn't say 16 valve. Which is what's putting me off. I just want a second hand rod but they only list the part numbers for the pistons. It's a 53 plate 2.0 dti signum.
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi if its a 2.0 dti then it will be a 16v as they dont do a 8 valve
    Mar 2011
    wigan
    It only has one cam with 8 lobes on. Any idea what it is?
    Sep 2010
    north east uk
    Quote Originally Posted by wolf_gsxr View Post
    Thats how the DTI is m8, each cam lobe opens 2 valves.
    As deano1 mentioned,the 2 ltr DTI is 16 valve.
