Thread: Can anybody tell me what this pip is
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Can anybody tell me what this pip is
    As in the title, the split pipe next to the dipstick
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes, its the sends the fumes from the engine into the airflow to the engine to be burnt off. It joins up to the black plastic thing on the left
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    As you can see its split, would this cause any issues?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No all it is doing is venting the engine. Some people put a longer pipe on and drop it down to the bottom of the engine and vent it to atmosphere. Then they block up where it joined the black plastic bit.
    I will be doing it to both our 1.9's soon as it means the engine burns cleaner air
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    oi mexican, need a word!
    Dec 2011
    Seaham
    On some cars a blocked breather pipe can effect the running. I had a blocked breather on a petrol volvo and it failed its emmission test for the MOT. Cleared the pipe and the emisions went back to ormal.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Quote Originally Posted by merikiito View Post
    Interesting, will that also make mpg better?
