Results 1 to 10 of 11
Thread: Low rev misfire. 2.2 petrol
    swansea
    Default Low rev misfire. 2.2 petrol
    Any ideas. Worse on starting off, unless you keep the revs up. Drives normal otherwise.
    Sep 2010
    Do you have a spanner on?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    have you got any codes could be the start of
    either fuel pump or regulator
    http://www.vectra-c.com/forum/showth...l-engine-fault
    swansea
    No lights yet, pump is 10 months old, and done about 14k.
    Sep 2010
    Quote Originally Posted by jrh1 View Post
    that doesn't mean it won't be that. My old 04 plate 2.2i direct developed a misfire (only slight) under load on the way home from a long trip. This again proved to be the fuel pump for the 3rd time. I went through 2 'redesigned' fuel pumps in less than 18 months
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    what about the regulator
    you need the codes read
    Sep 2010
    Do you know anyone who can plug in to check?... VX charge silly money for that, most local garages have this software and could tell you the fault code
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    coil pack??
    swansea
    Sorted. Thanks all, cracked plug. Thin black line mark down the side.
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. 2.2 Petrol Misfire/Stalling Help Needed
    By lfcfan85 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2009, 13:33
  3. 3.2 V6 Petrol GSi Misfire Under Load
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:22
  4. signum 2.2 petrol misfire
    By scotty6w in forum Engine & Drivetrain
    Last Post: 14th July 2007, 14:03
  5. Misfire
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2006, 16:30
