Thread: signum 2.2 missfire
    Sep 2012
    Wales
    Default signum 2.2 missfire
    my signum missfires on cylinder 1 at about 3500 revs.i put on a new ignition coil and went for a run.at 3500 revs the engine management light came on and the car would only go at about 10mph.after turning off the engine and restarting it everything was ok.went back on the road and it did the same thing again anyone got any ideas.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I not sure of the exact problem, I sure someone here will know.
    But keeping it simple for now, have you checked the air filter and checked/changed the spark plugs?
    If you can get to Wirral I can read the fault codes for you.
    Sep 2012
    Wales
    Quote Originally Posted by TonyP2020 View Post
    i checked the plugs before changing ignition coil pack they looked ok but i swapped them around and it still missed on cylinder 1.the car has only done 25000 miles.the air filter has done about 5000 miles.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    have you got any codes could be the start of
    either fuel pump or regulator
    http://www.vectra-c.com/forum/showth...l-engine-fault
    Sep 2012
    Wales
    i have a cheap code reader but it only reads engine management codes without the spanner and after restarting the car the the engine management code with the spanner is no longer on
  1. Idle missfire on my signum
    By mikemeister in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2012, 19:57
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  4. missfire 2.2 dti sxi
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:55
  5. 1.8 missfire.
    By 16vVec in forum Engine & Drivetrain
    Last Post: 19th September 2008, 20:02
