Thread: All sorted NOW!!!
    Regular Member kevinmc's Avatar
    Jan 2012
    Ireland
    Default All sorted NOW!!!
    I know it was posted b4 on the forum about, vectra 2.0dti lose of power around 3000revs spanner light comm'n on etc, thought it would have been egr.....and when put on a computer showed p01400 code. After getting second opinion it was the small vac.. pipes the ends of these where all split and cracked letting air in. All in all the bloke didn't charge me anything but I give him tenner for a good will jester as i know him well :-)...mine you it was a lot cheaper than egr valve and the prob... would have still exist, wee car fly'n now whooop whoop now i can past a tractor...lol
    Aug 2012
    Nice one Kevin - thanks for the heads up. Change the title though to something that will popup in a search on the forum for someone with a similar problem to yours.
    Glad you sorted it though. :-)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by jamesmcuk View Post
    The search function searches both titles and thread content
    Aug 2012
    Quote Originally Posted by John IS3 View Post
    I know but the search sucks so bad it pulls up loads of irrelevant posts and only displays the title. So if someone posts a title of "No power below 2000 RPM - Solved" I am likely to look at that much more than a thread called "Just an Update" or similar.
    It wasn't a criticism just a point because I spend ages searching posts on here only to find totally irrelevant stuff, probably because it does search both title and description LOL
    All the best
    J :-)
    Nov 2009
    Bristol
    If you use the 'Search Single Content Type' option and then select 'Show Results as:' Posts rather than Threads it makes things a little easier to find.
  1. so hopefully sorted
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2011, 16:58
  2. MOT sorted
    By peadar in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2011, 07:03
  3. Sorted at last
    By Telboy in forum Quick Photo Album
    Last Post: 10th April 2011, 21:19
  4. air con sorted
    By big tee in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2009, 16:21
  5. Car sorted now
    By Ian T in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2008, 18:01
