Thread: Retrofit Rain Sensor
    Edinburgh
    Engine : 1.9 CDTI 150
    Default Retrofit Rain Sensor
    I would like to know exactly what I need to retrofit rain sensors to a facelift vectra. Confused over JL and EX. When you look at opeloem it doesn't say on is for prefacelift and one is for facelift. Just different options.
    Your help is greatly appreciated
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    best thing to do is check and see if you have the loom installed if you have see how many pins it has the 3 pin one is EX the other which is 6 if memory serves me correctly is JL
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    for a facelift you will need the ex also you will need to replace the screen for the 1 used for rain sensor
    as its got the mounting bracket bonded onto the new screen.
    you will find that you will also have the ribbon already present as most of them do.
    this way you also be able to fit auto lighting so ya headlamps come on automatically when does dark etc
    pretty lot more mods you can do on the car
    Edinburgh
    Quote Originally Posted by john norris View Post
    i have the loom for a JL Sensor, so will this work on facelift.
    scottish region
    on the car or removed from an other vectra as the jl sensor wont work on facelifts it needs to be ex mate as far as i know and you dont need new windscreen as theres a kit on ebay for this mod
    Edinburgh
    Quote Originally Posted by DAVIDD88 View Post
    It was removed from prefaclift as wanted illuminated sun visors, nightmare, EX are so hard to find and so much more expensive than JL's. Oh well will have to put on hold then. as will need facelift roof loom as well then.
  1. Need Help with my Rain Sensor
    By nagnag in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2011, 20:07
  2. Auto dim mirror and rain sensor retrofit without GM loom
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2010, 13:54
  3. Rain sensor/Auto Mirror/Tuning box retrofit
    Last Post: 18th September 2010, 23:00
vectra c rain sensor auto
https:www.vectra-c.comforumshowthread.php172258-Retrofit-Rain-Sensor
vectra a rain sensor retrofit
