Thread: Fitting Parrot CK3100 with CD70
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default Fitting Parrot CK3100 with CD70
    Hi all,
    Going to be ordering a CK3100 unit shortly and wondered whats the best way of installing these units?
    I know there are the standard leads you can buy from autoleads etc but not sure which way to go about it.
    I've seen a couple of people mention that it can be fitted to the wires at the back of the glove box if they are present??
    Any guidance would be great
    Regular Member C-Owner's Avatar
    May 2011
    South London
    I've not fitted a CK3100 but have fitted lots of MKi 9200's to Vectra Astras
    You need to access the main wiring loom to the rear of the CD70 by removing it.
    Use a pre-made interface lead and remember to switch the yellow/red leads around to pick up ignition sensing,
    the Parrot (goodbye message) should be seen when turning off the ignition, if you dont see this when turning off the ignition its not installed correctly.
    Mount the main Parrot box under the CD70 behind the heater control panel
    Ensure all cables run from the CD70 away from the housing to allow the unit to be refitted without pressure.
    Aug 2010
    Pontefract
    Quote Originally Posted by C-Owner View Post
    Thanks for this help, I'm going to have a go at it. I was thinking about getting someone to do it but it seems like its fairly straight forward.
    Thanks again
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I have a 3100 in my elite , although my stereo is a ccr2006
    it is wired in to the loom behind the glovebox as this works as an "aux in" to the radio , this means that the cd is paused , the screen display changes to " message " and the phone volume can be turned up or down from the steering wheel controls .
    still needed to run an ignition feed from the fag lighter.
  1. Parrot CK3100
    By blackviper90210 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2012, 19:57
  2. Fitting Parrot CK3100 bluetooth car kit to VDA connector
    By James24 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2010, 20:11
  3. Fitting a Parrot CK3100 Handfree Kit
    By Mark Chambers in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2009, 14:43
  4. Help with Parrot CK3100 - CD70.
    By darrenh in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2007, 16:18
  5. Parrot CK3100 Fitting?
    By In a states in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2006, 16:00
parrot for astra wiring ck3100 cd70
vauxhall cd70 navi parrot
cd70 navi parrot ck3100
https:www.vectra-c.comforumshowthread.php172225-Fitting-Parrot-CK3100-with-CD70
parrot ck3100 vectra c
vectra c parrot ck3100
