Results 1 to 10 of 25
Thread: fitted twin exhaust sounds throaty
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Default fitted twin exhaust sounds throaty
    i have fitted a twin exhaust as title but sounds very throaty is this normal ??? its a 1.8 vvt 06 plate went from single exit to dual exit
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Probably yes, what type of twin exhaust is it? Any pics?
    Dec 2011
    liverpool
    6 Post(s)
    its off a 2.2 petrol and yes ill load some up now
    Dec 2011
    liverpool
    6 Post(s)
    Aug 2012
    Scottish Borders
    Loving the ramps...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Looks good, seem to stick out a bit though.
    Assume all joints etc are sealed up ok?
    Dec 2011
    liverpool
    6 Post(s)
    ye i thought the same bit to far out for my liking its because i have had to use a connector and its pushed the exhaust back about 20 mm but ye all sealed av tested them for leaks with a bubble tester and all is good
    Dec 2011
    liverpool
    6 Post(s)
    Quote Originally Posted by Lostie View Post
    Loving the ramps...
    the joys of mechanics in work hahaha can lend them if you want
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    I see you have the vxr splitter, i read some where the sri splitter will not come off as i was wanting to change mines to the vxr one?? cheers
    Quote Originally Posted by antowens View Post
    Aug 2012
    Scottish Borders
    As my Dad would say, "If it’s free and it’s useful, then make use of it"
    Used pallets before to get an engine into a bike, it was easier to put the engine on the pallets and lift the frame over the engine. Ahh the good old days.
    Think the rear of your Vectra looks really nice. How far are they sticking out? Looks about 40 -50 mm, When I replaced the front pipe I had to persuade it, to make sure it went all the way in as there was a tight spot, are you sure all the pipes are as far in as they should be and sitting correctly ?
  1. Twin exhaust now fitted
    By SRIDAN in forum Styling
    Last Post: 26th August 2011, 16:46
  2. Twin exhaust fitted today
    By blues n twos in forum Insignia car chat
    Last Post: 6th March 2011, 14:20
  3. Replies: 25
    Last Post: 26th February 2011, 20:00
  4. Replies: 15
    Last Post: 7th March 2010, 21:24
  5. CDTI throaty exhaust ?
    By Fash in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2009, 22:10
