Thread: Timing chain.replaced 4 years ago.2.2. Direct.told it needs replacing.
    Jun 2009
    Middlesex
    Default Timing chain.replaced 4 years ago.2.2. Direct.told it needs replacing.
    Timing chain clatters and been told they have modified it with a larger oil feed port.Told mine needs changing.Anyone advise on changing it?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    cant do any harm by changing it, mine was done 5000 miles ago (before i bought the car and is sated in the service log) but i will be removing the cam cover soon and taking some pics to see if mine has been fitted with the modifed bits, as i have no idear what was actually fitted 5000 miles ago if it aint been fitted with the upgraded one then ill have it redone.
    i also wonder if its the real vauxhall kit that is at fault, and acutally wonder if a different brand timing kit is better then a gm one, after all it is the vauxhall ones that fail.
    Jun 2009
    Middlesex
    Having trouble finding HOW2 for timing chain replacement on the 2.2 direct.VX want almost £800 to replace.Joke.
    May 2012
    northumberland
    http://www.vauxhall.co.uk/owners_ser...e-repairs.html
    £249 excluding parts (sure its gotta be excluding parts at that price?), but that price is up to 2.0 cant see why a 2.2 should be more expensive.
    11 Post(s)
    Quote Originally Posted by Dobs View Post
    The modified larger oil feed port was yonks ago when the Vec-B was still in production and should have been fitted to your Vec-C when it was built.
    The modified part is actually the chain tensioner. It's the one that's fitted to the 2.0 turbo engine and doesn't rely on hydraulic pressure to operate correctly. All chain kits should now come with with new tensioner unless you end up buying old stock.
  1. Replaced Timing Chain - Now Engine Whines !
    By Verns in forum Engine & Drivetrain
    Last Post: 13th June 2012, 22:33
  2. Timing belt/chain replacing
    By rob123 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 19:41
  3. 2.2i direct timing chain
    By LEEROB695 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 22:10
  4. 2.2 direct timing chain
    By degsy11 in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 20:10
  5. Timing Chain 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 15th January 2009, 10:59
replace timing chain on a vauxhall vectra 2.2i
