Results 1 to 10 of 14
Thread: IDS or not ???
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : signum 1.9 cdti 150
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Default IDS or not ???
    Hi folks, im replacing my front near side wheel hub/bearing soon as the grey plug lead to it got ripped off because the clip it sits in came free, since this ive got the abs and tc lights on.
    Ive priced up some parts and keep getting asked if my car has IDS, aint got a clue if my car has it, also should i replace the other side as well or doesnt it matter. While this is being done im getting new discs and pads too. thanks very much.
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Christ, would help if i told you i have a 2004 1.9 cdti 16v signum, lol. cheers.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Very unlikely. Have you got a sport button? I think im correct in saying if you dont then you dont have IDS
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    I don't think Ids was in preface all facelift hubs have Ids friendly hubs , difference between two is abs plug , give them ur chassy no and they will give u correct unit
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    you can get ids (cdc) on pre facelifts as ian c has it on his sri but it was a factory fitted option
    have a look on the front strut housings under the bonnet and if you have it then there will
    be a sensor on each strut or as already mentioned if you have the sports button that lights up wen you press it.
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Thanks for the replys folks, its weird as the non ids hubs im told have a black connector for the abs and the ids ones have a grey plug, my hubs have a grey plug so thats whats threw me off. dont think my car has ids as i dont have a sport button, the ones ive seen with grey plugs are like mine but im told they are for ids.
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    ok lets clear a few things up
    Although you car may not have the sports button nor the IDS sensors, if it has the round type pins on the connector (grey plug i think) then you are requiring the IDS hub, they fitted this after a certain year.... If the pins on the ABS plug are flat then that is the older type hub, my 05 plate one has the grey plugs and requires the IDS hubs
    36 Post(s)
    Engine : 1.9 DTH
    Think ian c had an 05 plate which must be full canbus think anything before that hasn't got ids
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    cheers guys, just wanted to make sure the ids hubs will fit ok even though i dont have the ids sensors, thats that cleared up so is it best to do bothsides or not??
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    no need to mate, just the affected side, its not like springs/dampers situation
has my car got ids on hub vectra c
removing opel vectra c ids sensor from hub
ids opel vectra c
vectra c 1.9dth ids sport video
dose vectra cdti 150 exclusiv have ids susspension
opel vectra c ids springs
Vectra c Z19DTH ids
does vectra c cdti 150 automatic have ids suspension
astra 100 edition coupe for sale
vectra ids suspension
