Results 1 to 10 of 20
Thread: Engine judder
    Aug 2012
    South Wales
    Default Engine judder
    Having some probs with the car at 19 cdti 150 but now I was pulling up a good hill in 3 rd at 2.5 k and she started to judder real bad changed down and she picked back up all ready done loads to it and now this any ideas
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    I would check the what colour the 3rd injector plug is, if its yellow it needs changing to the blue uprated version.
    The dodgy injector plug can cause the issue you had and eventually will break down further and cause even more issues
    what is your mileage?
    have you cleaned the egr valve out lately
    when was the last time you changed the fuel filter ?
    clean the throttle body.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    Aug 2012
    South Wales
    Done a fair bit of work so far
    new inlet
    Cleaned and stripped egr
    cleaned and stripped bcs
    new bcs vacume pipes
    cleaned and stripped throttle body and checked circuit bboard
    changed 3and4 injector wiring
    full service inc fuel filter
    new thermostat ( broke anyway )
    And a partridge in a pear tree lol
    it been having no boost under 2 k and been heavy on fuel lately that why I done all this do far but now the judder is way more prominent and more often any ideas
    Aug 2012
    South Wales
    Oh And forgot cleaned boost sensor and blanked egr
    West
    does your dmf rattle? mine would judder a bit if i was in the wrong gear on an incline prior to replacing the dmf.
    West
    In addition... is the swirl bar intact & moving as it should?
    Aug 2012
    South Wales
    Swirl bar fine all ok what is the dmf sorry learning as I go along here lol
    West
    Swirl bar can be seen by looking in the glow plug area with engine cover off (little bar connected to the 4 swirl flaps) should move when engine is revved. DMF = dual mass flywheel, is there any rattle on idle?
    Aug 2012
    South Wales
    No there no rattle on idel it a bit lumpy between 1 and 1.5 k and then just that judder or miss around 2.5 k when pulling hard I actually watched the rev counter loose 500 then just pick back up
  1. Z30DT Engine Judder
    By ph67 in forum Y & Z30DT Specific
    Last Post: 12th January 2017, 20:05
  2. Engine judder
    By pipamish in forum Engine & Drivetrain
    Last Post: 24th March 2012, 18:24
  3. another engine judder thread
    By rob warrington in forum Engine & Drivetrain
    Last Post: 6th September 2011, 08:58
  4. Low Rev engine judder.
    By super sleuth in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 19:56
  5. smoke and engine judder/lag
    By phiniasfreak in forum Engine & Drivetrain
    Last Post: 27th April 2009, 13:33
