Thread: rear calipers
    Regular Member ant6566's Avatar
    gwent
    rolleyes rear calipers
    just spent 4 hours trying to unsieze the rear caliper on the car,it was the piston stuck solid.tried winding back in but no luck,so ended up taking caliper off, and resorting to a vice and water pump pliers.would have bought a new one but 2 day wait at vx dealer,and need the car for work.all fixed now,but have to check the other side on weekend.prevention is better than cure i suppose...
    Dec 2011
    Seaham
    Rather then take it off and using a vice, try using a G clamp to put on pressure as you wind it back.
    South east
    You should check it again this weekend, to make sure it's still moving freely.
    Nov 2009
    newcastle
    Same happened to mine. Garage couldn't get them 2budge. They seized on at 3am which was fun. 2 new ones fitted. Told mine happened cos allowed discs n pads to go fairly low and piston at full reach so more likely to happen (and 226k on the clock)
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I can sympathise with the OP on this, I actually ended up damaging the piston seal whilst trying to free mine off, after that I was determined to get it off! Got there in the end, still need to replace the seal though
    Jun 2006
    St. Helens,Merseyside
    i managed to wind the pistons back on both read calipers, then once tested the both leaked so got replaced with genuine GM recons from local motorfactors
    Quote Originally Posted by ant6566 View Post
    Which rear caliper had seized, near or offside?
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    there is a tool u can buy i did this and it is much easyer mines was 20 odd quid but i think u might be able to get them cheaper from ebay.
    Engine : Z20NET
    I was using a proper rewind tool but it kept slipping, eventually got it to bite.
    Mike if thy were leaking why didn't you just replace the seals?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Mine were tight when we changed the pads and discs. We just stipped the caliper off of the car fitted the rewind tool in position, but left it a little bit slack then gently pressed the brake pedal. This was enough to free the piston and it wound back easily after that.
    3.2 v6 Signum and loving it
  1. eBay rear calipers
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2013, 00:54
  2. For Sale: 292 rear calipers
    By plasma in forum Parts for sale
    Last Post: 25th November 2011, 20:23
  3. VXR rear calipers?
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 13:41
  4. Seized rear calipers or not
    By stitchi1973 in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2009, 19:45
  5. Painting Rear Calipers
    By parapaul in forum Styling
    Last Post: 13th February 2007, 22:26
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
