Thanks Thanks:  2
Results 1 to 10 of 22
Thread: CIM Replacement - Programming
    Regular Member any-mgzt's Avatar
    cheshire
    Trim : basic
    Engine : Z19DT
    Default CIM Replacement - Programming
    I have the Steering wheel and exclamation mark symbol on and having read the forum multiple posts have come to the conclusion that its the CIM, Vectra 120hp 99,000mls, so given the milage its the CIM.
    Additionally cruise no longer works. Error codes can be cleared but return as soon as the wheel is turned.
    C1532 - Steering Angle Sensor Signal Circuit Open or High Voltage
    (05) - Present
    U2105 - CAN-Bus no Communication with ECM (Engine Control Module)
    (00) - Not present
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    Can a replacement CIM, that has been divorced from previous vehicle, be programmed with anything other that Tech 2????? Or do I have to use Tech 2?
    I know someone who is willing loan me a Tech 2 for a weekend, how diffricult is it to programme?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you checked that can bus wires are complete?
    cheshire
    Trim : basic
    Engine : Z19DT
    Yes checked all wiring, removed connectors cleaned with contact cleaner and replaced, as I said I have read the many posts on here and followed most of the advice.
    The car itself has been a pain since I bought it, turned out to have been a cat D right off, and put back on the road by a cowboy, in short the front offside chassis had just been pulled back to shape and real damage not repaired. Long story not willing to go into more detail here.
    I think many of the problems I have had are related to the possibility that the electrics may be from more than one vehicle.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If it it is a smash repair I'd check may even need a scope to confirm can bus wire operation.
    As far as I no a previously divorced unit can be programmed in.
    Best to ensure you have a note pad an pen to hand to note down all the variant coding etc
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    As long as new CIM unit is either tech2 cleared or supplied with code u gonna be fine , however if u not familiar with tech2 yourself that's another matter
    cheshire
    Trim : basic
    Engine : Z19DT
    Having checked some posts where they reccommend looking at the fuses in relation to the EHSP light, I checked my fuses and find that fuses 18 "Ignition terminal 15 air conditioning" and 21 "Infotainment" are missing?????????????
    I pulled fuses 17 and 26 and checked them both found to be sound, tried ignition and EHSP light had gone out but reappeared after around 30 seconds.
    cheshire
    Trim : basic
    Engine : Z19DT
    Tech2 can't be that hard to learn???
    Sep 2011
    Paisley
    I got a second hand CIM unit for my 52 plate 2.0DTI from Megavaux and it had it's codes cleared. I then got a local guy with Tech2 to program it into my car for £80. All I needed was the VX car pass.
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by mcally View Post
    £80 for some local guy to programme it. It would have probably been cheaper to go to the dealer to have it programmed
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    depends if its fitted as well or just purely programmed,
  1. Key fob programming ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2016, 05:12
  2. GID Programming
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2012, 14:09
  3. Fitting replacement engine tech2 ecu programming??
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 1st July 2011, 18:51
  4. Key programming
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 22:18
  5. key programming please
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2009, 22:02
https:www.vectra-c.comforumshowthread.php172170-CIM-Replacement-Programming
vectra cim module replacement
vectra c cim programming
cim module opel vectra c
cim module vectra c
vectra c cim module repair
vectra c cim module
vectra c cim replacement
opel cim module problem
vectra cim
vectra c cim module reset
vectar cim moduel
vectra c cim repair
moduł cim vectra c
cim programming
How to program vectra c cim
cim replacement with tech2
vectra c cim module location
if i change my cim module on my vectra c do i hqve to get it programmedSIM unit vectvectra c cim faultinsignia module programmingopel cim repaircim modul vectra cHow to reset a CIM on a vectra
