Results 1 to 10 of 17
Thread: Occasional Heavy Blue Smoke (150 CDTI)
    Merseyside
    Default Occasional Heavy Blue Smoke (150 CDTI)
    Hey everyone,
    After a couple of months trouble free, I've noticed that the car occasionally smokes heavily (thick blue smoke) on acceleration. There are no warning lights at all and there is no loss of power at all.
    I can see that the computer readings plummet - Avg MPG and Range fall heavily. I've had the DPF taken out but suspect that its not been mapped out properly. Could this be the cause of the smoke?
    The Turbo doesnt appear noisy and as I've said, theres no apparent power loss. No error codes either...... Could it be the ECU thinking the DPF is still there and chucking diesel in to the exhaust to regen it? Or could it be something more sinister?
    Andy
    Jan 2012
    Silverstone village
    Removing the Cat and DPF will make the exhaust free flowing and will result in additional unburnt fuel from th exhaust, I have noticed this after de-catting a Ford Mondeo, with no DPF.
    I thought the re-gen only happened when the ECU detected enough back pressure from the DPF and a sign of it blocking..?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Merseyside
    I get the DPF regen 'judder' though. I might have to get it checked to ensure the DPF has been taken out properly. I have a suspicion that its the DPF again, as I dont think its been taken out properly. Pain in the backside!
    Merseyside
    Theres no results for this search mate....
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Call masperformance.co.uk and see if they a have a local agent, should cost you £220 to have the DPF and EGR mapped out plus a performance/economy map
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Merseyside
    I've had a search for similar posts, and note that there may be a suggestion that the Turbo may be on its way out and blowing oil, hence causing the blue smoke. Would a knackered Turbo cause the intermittent smoke or is it likely to be something less sinister??
    Merseyside
    I've had another thought...... Because the engine was pretty much neglected by its previous owner, I've been adding Millers Diesel additive for the last couple of tank fulls to give it a clean out - could that have loosened some cack inside the engine causing it to burn off and cause the smoke?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I found Millers additive cause me issues when I used it resulting in random smoke, I have changed to BG 244 which is much better and always imporved the cars running.
    http://www.ebay.co.uk/itm/BG244-BG-2...item564a9d4cc9
  1. Signum 1.9 cdti 150 Blue Smoke
    By Kyletasker in forum Engine & Drivetrain
    Last Post: 6th July 2012, 19:02
  2. Diesel filled with petrol - now occasional smoke
    By AntSSSS in forum Vectra C / Signum Troubleshooting
    Last Post: 5th March 2012, 22:38
  3. Blue smoke sluggish 3.0 v6 cdti
    By Dam3dx in forum Engine & Drivetrain
    Last Post: 24th January 2012, 16:14
  4. blue smoke on 1.9 cdti 150
    By big nath in forum Engine & Drivetrain
    Last Post: 26th November 2010, 09:44
  5. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
cdti occasional smoke
intermittent blue smoke from exhaust vectra cdti
vectra cdti 2ehn
zafira 1.9 cdti intermittent smoke
vectra c 19cdti intermittently blue smoking
vectra 120 occasional blue smoke
zafira sri 1.9 cdti intermittent smoking
https:www.vectra-c.comforumshowthread.php172161-Occasional-Heavy-Blue-Smoke-(150-CDTI)
vectra c 1.9 cdti occasional blue smoke
vauxhall vectra c cdti blowing intermittent blue smoke
