Results 1 to 10 of 14
Thread: 2.2direct problem
    Midlands
    Angry 2.2direct problem
    Hi i`m having a problem with my 2.2direct, It all starts ok and idles fine but when I put my foot down it seems to be holding back between 2-3000 rpm then ok again after that. It does it in every gear but only between 2-3000 rpm above that and its fine. Any one had this problem before or have any idea what it could be??
    Sep 2010
    dare I say it 'fuel pump'?.... I had three fitted to my old 04 direct, 2 of which were supposed to be the re-designed version. all failures had slightly different symptoms.
    Midlands
    Is there any way of testing this this to make sure as I dont want to spend £300 on a new one and find out it`s not the problem. How easy is it to replace? is it a diy job?
    Thanks for the reply.
    Midlands
    another question -If the fuel pressure regulator is disconnected what should happen to the engine? should it still run ok or should it cut out??
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    diy job to replace, one of the easiest fixes you can do - if you need to replace, i belive one of the rubber seals split inside the pump, if your good with spanners and tools you could probably take apart your existing pump to check the seals for splits.
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Quote Originally Posted by Barnes View Post
    If im correct I think it should cut out buddy, as I think if its the pump at fault it sends the car into limp mode as there is no pressure (thats what it did to mine), but I think if its the fuel reg the car runs for a little but then has no power what so ever so the car is undrivable (thats what happened to mine)......
    Midlands
    OK, If I disconnect my fuel pressure reg it still runs exactly the same as it does when it`s connected
    Dec 2010
    Boosting in W.Mids
    Trim : Aero
    Mileage : 62000
    Have you tried driving without it plugged in?
    Midlands
    Yes mate, It doesn't make any difference at all.
    Midlands
    I have read a few posts from people experiencing similar symptoms to mine who have said it`s something to do with the swirl flaps in the inlet manifold sticking, Anyone has this problem? how does it affect the cars performance? Cheers
  1. Bye Bye 2.2Direct
    By Discreet in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2012, 21:33
  2. 2.2direct sri gearbox
    By vec22direct in forum Engine & Drivetrain
    Last Post: 23rd May 2012, 00:05
  3. 2.2direct gearbox
    By vec22direct in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 17:35
  4. 2.2direct Big problem need a good bit of advice please
    By Kcriyback in forum Engine & Drivetrain
    Last Post: 12th March 2012, 01:34
  5. My SRi 2.2Direct
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2009, 14:44
