Thread: help with tech2 programming auto AFL
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    Default help with tech2 programming auto AFL
    hi all,
    Apperently my local opel dealer here in Denmark is'nt used to program Vectras with AFL headlights.
    I was wondering if someone in here could give me programing settings for using the light button on auto and then it should turn on the light when my sensors registrer rain or "darkness"
    hope to hear from you guys.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Something like this mate.
    UEC, set rain sensor to present
    BCM, set auto headlight switch to present
    REC, set rain/light sensor to present
    REC, set auto dimming mirror to present
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    thx mate, i'll guess Opel will now what you mean by UEC, BCM, REC ?
    Also after they had it a week ago the feature with drivers side mirror moving down has stopped working - any idea what they done?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by emsedk View Post
    UEC=UNDER BONNET ELECTRICAL CENTRE (FUSEBOX UNDER BONNET)
    BCM=BODY CONTROL MODULE
    REC=REAR ELECTRICAL CONTROL (FUSEBOX IN BOOT)
    If they're worth their salt they should mate. Maybe they've turned that option off!
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    thx again black knight - i'll set my self on top of them with programming now and hopefully i'll get it working
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    No problem mate,
    Scotty
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    If you only changed for the autoligth switch.. And had the other bits all ready.. it should only be the setting on the BCM thats missing..
    And if your friendly dealer wants the normal 1000 DKK come by me and ill sort it out...
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    OK - Ken, jus pm'ed you
    Engine : 2.2 Direct
    And replied
  1. UHP4 BT TECH2 programming
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2016, 23:22
  2. Fitting replacement engine tech2 ecu programming??
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 1st July 2011, 18:51
  3. Tech2 Programming.
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 20:55
  4. Need help 4 TECH2 Programming
    By emsedk in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2010, 20:51
  5. Programming the auto gear box?
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 11:05
how to turn afl headlights on vectra 2004
instaling afl headlights vectra
