Thread: Cosra b v reg what to look for
    Jul 2011
    UK
    Year : 06
    Default Cosra b v reg what to look for
    The other halfs grandma wanting me to look at this car it's a v reg petrol with 48k on the clock what should I look for be costing 400 pound
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    rattling timing chain would be the main one if its a 12 or 16v petrol .
    then just the usual broken springs , rust etc to look out for .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    This is a must fella when the engine is running look at the right side of it the ecu is there wiggle the black plug connection to the ecu see if the car dyes they have a problem with water ingrestion cause bad connections to the fuese box and replays usally the switched neutral that breaks had loads of the with the same problem
    Full Member RBH's Avatar
    Jan 2008
    North Lanarkshire
    88 Post(s)
    Vehicle : INSIGNIA
    Trim : VX LINE
    Engine : 2.0 CDTI
    Mileage : 44000
    rear wheel bearings.
    boot floor at spare wheel well.
    window seal on boot.
    Jul 2011
    UK
    Year : 06
    Cheers lads well the car came to us first impression was Jesus what a mess lol the o/s has been badly repaired needs resprayed couple rust spots nothing major knocking drive shaft on right lock engine is sweet as a but suspension is very strong and tight not a bad car realy it's a 16v unsure engine size said 300 quid and all fix it up and reprint the o/s
