Thread: error code p112-61 swirl flap stuck
    Regular Member dahmich's Avatar
    cwmbran
    Default error code p112-61 swirl flap stuck
    ive been having a little lumpy idle (z22yh) and thought id get diagnostics on the case, it came back with something i wasnt hoping for. swirl flap stuck. now ive been doing a bit of reading and it varies, but i have no other fault codes apart from one on the CIM, which im guessing has no bearing on the swirl flaps altogether.
    whats the best way to fix please!! ive not long replaced the faulty egr and was looking at blanking but need this sorted asap!
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Oooo take the inlet manifold of fella give it a clean up see if you can free the flaps up
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    There is a Swirl Flap mod kit for this engine. I too am having a problem although my fault code is P1112, not like your P112-61.
    I have had the mod kit fitted and also put a new MAF sensor on. All to no avail as I'm still having the emission light and code come back after about 25-30 miles of having it cleared.
    Taking the car to Vauxhall for further diagnostics to see if they can pinpoint the exact part that is faulty.
    cwmbran
    just read this from this thread http://www.vectra-c.com/forum/showth...p-please/page4
    Field Remedy: 2233
    Subject: Engine Z22YH - Engine malfunction controllamp illuminates, trouble code P1112 (64) stored
    Models: Engines: Option:
    Zafira-B 2005...,Signum 2003...,Vectra-C 2003... Z22YH,Z22YH,Z22YH
    Complaint: Engine malfunction controllamp illuminates, trouble code P1112 (64) stored.
    Cause: Swirl flaps on the air intake manifold sticks.
    Production: Introduction of improved swirl flaps in production as of engine-no.:11674296 (03.07.07).
    Remedy:
    In case of customer complaint replace the control link and the swirl
    flaps. A repair kit (control link and swirl flaps) is available via
    P&A with partnumber: 93192896 / cataloguenumber: 8 49 674.
    Note: It is not necessary to change the complete air intake manifold.
    FunctionalGroup: J - Engine
    Complaint Group: 19 - Poor Engine Driveability
    Trouble Code: P1112 (64)
    theres a update on the field remedy apprarently lastest one it here.
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    Yep, thats the kit I had fitted but I still keep getting the emission light on with P1112 fault code.
    Regular Member VeCeZ22YH's Avatar
    Jun 2011
    Bratislava
    Engine : petrol 2.2 i 155 PS
    Hi. fault P1112 - Swirl Flap Stuck (61) - Not present, is stored in ECU DTC . no emission light comes, engine starts poor when it is hot and driveability is not as good. I guess manifold needs to be taken off. Is it hard to take it off or can anybody give any advice?
    thanks a lot
  1. swirl flap
    By elite lee in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 21:49
  2. Hi CO and Swirl flap code P1112
    By silflex9 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 11:44
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Help pls - Petrol Flap stuck!
    By moorlander in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2010, 10:55
swirl flap stuck
Opel DTC P1112-64
swirl flaps vauxhall zafira
p1112 swirl flap stuck
vectra swirl flap stuck
vauxhall zafira fault code 112
fehlercode p1112-64 vectra
p1112 opel vectra c
p112 osibka opel
vauxhall p112
swirl flaps stuck closed
swirl flap and throttle stuck closed 3.0 vauxhall
на зафире б 2 2 мотор ошибка p1112-61
z22yh swirl flaps
intake manifold twerl flaps on vectra c 2.2 diesel 2004
2.2i signum swirl flaps
vectra b intake swirl flaps
swirl flap struck
Vauxhall zafira p112 fault
swirl flaps vauxhall signum
has a Vectra v6 got swirl flaps
p111261 zafira b
code 61 zafira
111261 vectra c
