Results 1 to 10 of 15
Thread: EML on,noisey turbo,really bad smoke,oil light flashing on,please help anyone
    Dec 2011
    ROTHERHAM
    Default EML on,noisey turbo,really bad smoke,oil light flashing on,please help anyone
    im a taxi driver with a vectra cdti 1.9 08 reg done 126000 miles,run for months with eml on as problem didnt effect running car,then car developed noisey turbo like a whining,hissing sound that got louder on more revs,i still ran car just easing off throttle to quieten the sound,i did notice that turbo wasnt kicking resulting in slow build up of power.then last night smoke was pouring out of exhaust really bad,cant stress how bad in words.also noticed oil light come on,can anyone comment as i need it back to normal asap thanks,brian
    Jul 2012
    Lancs
    I'm no expert Brian but, it sounds to me, youve goosed your engine mate. You ran for months with the EML lit and ignored a noisy turbo-as you sow so shall you reap.
    Aug 2012
    South Wales
    Sounds to me like your turbo gone mate with the oil seals blown that would chuck a load of oil back into the Inlet and cause the smoke would explain the oil pressure drop and the noise if it is the turbo and you get it repaired make sure the take the intercooler and clean it most prob be full of oil and don't be surprised if when repaired it still smokes for a while as it gonna blow any residual oil through the system will also need to keep an eye on the cat and dpf if you got one
    Dec 2011
    ROTHERHAM
    thanks guys for ur replies,looks like a trip to the garage tomoz and not sounding cheap after looking at turbo,s on ebay.started it today and starts ok with no smoke but noisey from where turbo is at front,cant run it tho as ive lost all oil somewhere with oil light on.can anyone else give there views or coment please so that i can pass info on as my local garage will fit allsorts to find the cause and bill me acordingly,im already considering if its cheaper to buy another car,thanks brian
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    sounds like the turbo has failed in a big way , then the engine burnt the oil as it went through the turbo seals
    Dec 2011
    ROTHERHAM
    thanks for info ive heard this a few times now so guessing i need seals and pump,thanks to all,brian
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    you need a new turbo and hope there's no damage from the oil going through your engine
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    New turbo.
    All inter cooler paperwork an exhaust will be flushing
    New oil an filter. An then drop again after couple hundred miles. An you should be ok.
    Dec 2011
    Seaham
    Lucky it didnt run away with you, otherwise it could have been much worse.
    Dec 2011
    ROTHERHAM
    could have done without spending out on a turbo but im confident now its the turbo after reading posts on here,although around 6 months back i had timing belt done and have read that it could be a tensioner thats gone and this could cause smoke and power loss,anyhow im going with turbo and seals,just hope it drives the 3 mile to garage tomoz
  1. Ps3 Red light flashing
    By bigmac in forum Games Room
    Last Post: 15th October 2010, 12:42
  2. oil can light flashing
    By jstal40024 in forum Engine & Drivetrain
    Last Post: 15th June 2009, 13:10
  3. noisey turbo 2.2dti
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 18th November 2008, 11:36
  4. flashing light
    By craigmerry in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd February 2008, 21:20
  5. Noisey Turbo When Cold ??? 1.9 cdti 150
    By Longtallhowie in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2007, 08:55
