Thread: (More) Barmy wipers!!
    Jul 2012
    Lancs
    Default (More) Barmy wipers!!
    Hi all, I've done several searches and it seems I've a new issue, my wipers refuse to park in the normal position (they're parking about 17 degrees from horizontal) although when on constant, as opposed to intermittent, they sweep the windscreen normally. So, any ideas Guys?
    Cheers, Ian.
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Jul 2012
    Lancs
    No. As I said I did a search and the fault is NOT the same as the one you've highlighted above, my wipers don't park randomly about their swept area but simply park at an angle near the bottom of the screen. They don't foul the trim at the top of the stroke nor the scuttle panel at the bottom of the stroke so aren't fitted to the spindles incorrectly. It's no so bad it can't be lived with and certainly won't fail an MOT so I'm gonna assume that short of replacing the entire wiper mechanism I'll have to live with it should (genuine) illumination not be forthcoming from this august body.
    Cheers, Ian.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    sounds like they are set wrong , assuming they do hit the lower level of travel when switched on then either come back up to rest , or go down then up when switched on.
    if so then loosen the nut on the motor where it connect to the crank arm , re-align the wipers & tighten the nut back up
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    If its the same as my old siggy then it will be the motor, mine started off by not parking at the bottom of the screen and then over a couple of weeks parked higher & higher up the screen. Had to change motor in the end.
  1. Wipers?
    By GAV_SRI in forum Troubleshooting
    Last Post: 5th December 2010, 22:45
  2. Wipers
    By slipperysam1984 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 13:53
  3. Wipers...
    By ROY2593 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 20:14
  4. wipers
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2008, 20:46
  5. Wipers
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2008, 12:05
Vectra c wipers go down then up
