Thread: Limp mode on my 2.0 dti and fault code is p0243.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default Limp mode on my 2.0 dti and fault code is p0243.
    my veccy 2.0 dti has been playing up my mate plugged his magigal tool in and it came up P0243 Boost Pressure Valve Position Sensor.does anyone know what it is and where i can find it on my engine?thanks.
    Aug 2012
    usually related to the Turbo wastegate valve but could be other things that cause the symptom, but start by checking that the gate is working properly
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    is it on the side of the throttle body?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    DSCF0002AA.jpgDSCF0003AA.jpgIMG_3211B.jpgDSCF0001AA.jpgthe turbo wastegate is attached to the turbo itself
    Also worth checking that the vacuum hoses dont have any splits or signs of perishing , this is a common problem on the Dti,s .
    best bet is to change all the rubber vacuum tubing with silicon tube , you need three meters to do a DTi , cost ,s around about £7 on e bay
    and still loving it
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    my car has only one bulkhead actuaor.there is a plug next to thre one i have.never had this before.
    Engine : 2.0DTi
    Mileage : 73350
    Some of the Dti s only have the one because they dont have the TP sensor on the inlet manifold, see third pic .
    and still loving it
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    thanks mate.its still doing it.limp mode.i cleaned the sensor with mr muscle oven cleaner is this damaging the sensor do you think?
    Engine : 2.0DTi
    Mileage : 73350
    Get your misses or a mate to rev the engine for you while this is going on see if the wastegate diagfram arm is moving on the turbo.
    You may have to rev the car up to 2000 rpm to get the arm to move if it does not move then i would suspect that you have a leak in the vacuum hose system this will cause the car to go into limp mode .
    Would not exactly recommend mr muscle for cleaning boost sensor,s, but hey each to there own
    and still loving it
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    so why would the diagnostic come back boost pressure sensor?cant really push the turbo as goes str8 into limp mode onlt revs to just under 3k revs!!!
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    so is it the sensor or what?the tool doesnt lie.it says boost pressure sensor,would this say that even if it was dodgy pipes?
  1. stuck in limp mode p 1604 ecu code
    By christopher8079 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 16:07
  2. Fault code and limp mode
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 7th February 2012, 20:58
  3. Anyone got a code reader? My car is in Limp mode... :(
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th March 2011, 00:40
  4. Fault code 1901 and limp mode ?
    By ajr in forum Engine & Drivetrain
    Last Post: 30th December 2010, 01:27
  5. Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    By danBoy in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:45
p0243 signum
Vectra c 2.0 dti p0243
vectra 2.0 dti p0243
p0243 2.0dti
