Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Tech 2 reqd urgently car off road help anyone
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Default Tech 2 reqd urgently car off road help anyone
    Hi guys well driving home speedos rev all dials dropped steeeing went heavy thought it was alternator however wheen mr aa turned up he thoughtsame but immobiliser has kicked in the should be 60 ohms across the canbus system he says?? Mine has none indicating a break in tbe system and says i need a tech 2
    So.......
    Has anyone got one and be willing to come over to mine to check the car help see if we can find out the problem
    Need car for work but im snookered without it
    Many thanks
    Stu
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Could this be a CIM failure?
    Also check fuse 17 in the Dash Board Fuse box
    May 2011
    I would have said that on an astra but could this be the same on my vec??
    Jan 2012
    Milton keynes
    Mileage : 38100
    Could happen on any car... I've read it a few times on here.
    I'd be checking all the fuses first... which I assume the AA guy did?
    May 2011
    Yeah checked fuses mate.
    What exactly does cim failure mean?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Take it he wasn't able to jump it into life mate? Long shot but take the ABS plug off, give it a squirt of wd40.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Column Integrated Module. Its basically the hub which all the low,mid and high speed CANBUS networks go to, along with your immobiliser and ECU's. its right on the steering column and the car wont work without it. As Dasarab has mentioned, the ABS plug on the module in engine bay can become corroded. Give that a looking at too... and check fuse 17 in the dashboard fuse box!
    May 2011
    Tried that mate but immobiliser stoped it like
    May 2011
    CIM that sounds very expensive??
    Jan 2012
    Milton keynes
    Mileage : 38100
    Can be... I'd estimate around £500...
    Edit - Try disconnecting the battery for a while, see if that "resets" the CIM modules etc...
  1. URGENT HELP REQD!!!! on SIDE OF ROAD
    By Big Red in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2012, 18:34
  2. Vectra c cim module & tech 2 help needed urgently
    By vectradave2011 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2011, 17:30
  3. Need Help Urgently Please
    By jammin31 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd June 2011, 15:15
  4. Trolley jacks reqd
    By bobssignum in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 01:47
