Thread: 1.9 CDTI (150) Back pressure
    Aug 2012
    NorthEast
    Default 1.9 CDTI (150) Back pressure
    I have just fitted a pipercross Air filter and done a few checks around my engine as normal, oil water etc..... AND
    i took my oil cap off where you put your oil in and i can feel quite a bit of back pressure also spitting oil, is there and reasons for this cause i though if that happens its an OLD engine?
    This is an 06 vectra.
    All feedback welcome
    Carnoustie
    I think it will spit oil out if cap removed, lift dip stick check for smoke?
    May 2006
    scotland
    yes it should spit a bit. Healthy sign IMO, it means the oil is getting to lubricate the top parts of the engine. If were a gush like striking an oil well, then I would be concerned.
    Aug 2012
    NorthEast
    Im a bit worried still.... car preforming good still though.... and no smoke coming from the dip stick area
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    if it aint broke dont fix it!!
    Jun 2012
    lancashire
    on another note mine does the same
    cams are there pumping up and down right near that hole and they are all squirted with oil
    if there was not a sign of oil id be worried
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    as above, it will cover the engine bay if u remove the oil cap, its normal..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Boost pressure - CDTi 120
    By zafira in forum Diesel Engine related
    Last Post: 23rd October 2010, 20:10
  3. Back pressure in the turbo
    By mrpatterson2008 in forum Engine & Drivetrain
    Last Post: 22nd July 2010, 01:08
  4. 1.9cdti back pressure
    By bigjoe8707 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2010, 17:00
  5. What is Back Pressure ??
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 00:15
smoke coming from dipstick 1.9cdti
vectra c 1.9cdti oil and smoke coming out of oil cap
