Results 1 to 3 of 3
Thread: Can't remove inside rear view mirror
    Nov 2011
    Valkenswaard
    Question Can't remove inside rear view mirror
    I'm trying to remove my standard inside rear view mirror from my Vectra C facelift (2006) in order to replace it with an autodimming one.
    But I can't get the thing removed from the windscreen.
    I've read in other threads that it should glide downwards the windscreen towards the dashboard.
    When trying it slides indeed about 0,2 inches and then stops. It feels if its been blocked then.
    What should I do? I don't want to damage either the mirror or screen.
    Engine : 1.9 CDTi
    There is a little tab that needs to be pulled away from the screen to allow it to slide.
    Unclip the plastic cover as much as you can and you should see it.
    I used a small screw driver to pull the clip down.
    Nov 2011
    Valkenswaard
    Thanks, that did the job.
    Very simple to do when you know how.
    I put a small srew driver between the top of the plastic cover and the windscreen. Then sliding down was easy.
    Thanks to Lee GSI
  1. remove interior rear view mirror
    By brasch in forum Styling
    Last Post: 24th March 2014, 18:43
  2. How To Remove Auto-Dim Rear View Mirror
    By lew1984 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 10:55
  3. Rear View Mirror Blocks all View to Left
    By bren in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 21:36
  4. Rear View mirror
    By 2.2DTISRI in forum Vectra C / Signum Troubleshooting
    Last Post: 6th March 2008, 13:03
  5. Rear View Mirror
    By Rob_the_Scot in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2006, 18:06
interior rear view mirror vectra c remove
