Results 1 to 10 of 11
Thread: Clutch Failure?
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Clutch Failure?
    Guys can anyone shed some light on my problem,the thing is when the car is stationary an i`m about to drive off i put the car in 1st gear and reach biting point the car seems to shudder or vibrate,this only happens in 1st gear and has just recently started.Is this a sign of clutch and dmf failing?Thanx in advance.
    Derry
    anyone please?
    Dec 2011
    Seaham
    Could also be contamination of the plates or weak clutch springs on the cover plate??
    Derry
    Thanx for your reply ben,is there any way to tell the difference?
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    1.8?
    Derry
    2.oltr dti m8
    Dec 2011
    Seaham
    Only by stripping it down.
    Wasnt there a spring replacement for the clutches?? Or am I making this up?
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    spring for clutch pedal. i was thinking of the famous juddering on the 1.8 clutches which they were replacing...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Dmf sounds fooked to me
    Aug 2012
    sounds like clutch maybe worn. A car of mine used to do the same but only after being sat in traffic for a while (stop start etc) DMF usually makes a noise when failing that can be heard even when not in gear and pressing the clutch in a bit. Also maybe a multitude of things not mechanically related such as Clogged EGR, Fule Filter, Air Filter and maybe even leaks in the vac pipes. ANy of which could be costing you low end Torque and so the engine is stuggling to get the car going.
    Test the clutch by getting to 10mph or so then wacking it in 3rd/4th and flooring it. If engine and speed stay in time then clutch is probably not in to bad shape. if the engine speed (rpm) goes up without much pickup in road speed the clutc
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. MOT Failure or Not?
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 14:50
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  5. MOT Failure
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 19:22
