Results 1 to 3 of 3
Thread: Will calibra V6 (2.5) engine parts go on my GSi (3.2) engine ??????
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Will calibra V6 (2.5) engine parts go on my GSi (3.2) engine ??????
    Hi All,
    I have the chance of an engine from a calibre V6 – the guy has put a lot of new parts on it to get it running plugs, water pump, thermostat etc. and he has a new timing belt/kit with all the tensioners. It’s a project a neighbour was doing and he needs the space – he is looking for £150 (Apparently the engine had a catastrophic failure internally but he has fitted new gen Vauxhall parts with a view to getting it running again).
    Wanted to ask if the 2.5 calibra (which I’m assuming is the same as the B GSi) bits are a direct swap for the 3.2 as having things like spare coil packs, alternator and all the other bits could save me a lot of dosh if I need to replace things.
    Glasgow
    Very much doubt anything will be of any use, even things down to a bolt on alternator may not be the same spec.
    Bear in mind the calibra was based on the cavalier so is very much out dated technology.
    Jul 2006
    greenock
    I was a bit dubious but he was confident that a lot of the parts (plugs, water pump, thermostat, timing kit, etc.) were the same (it probably does not have coil packs thinking about it). Although it is a different part number it’s the same thing – that's obviously his take on it but was hoping someone on here could tell me if that was the case or not.
  1. Painted engine parts
    By marc vectra sri in forum Styling
    Last Post: 25th May 2012, 12:42
  2. 3.2 Engine parts.
    By fluffsri in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2009, 15:42
  3. Modifying engine parts
    By Spikey© in forum Petrol Engine related
    Last Post: 21st August 2006, 20:01
  4. Blue Vec with Red engine bay parts
    By Jay in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2005, 23:00
calibra v6 parts
