Results 1 to 10 of 18
Thread: signum dti hard to start when warm
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default signum dti hard to start when warm
    hi i have a 53 reg signum dti and its hard to start once warm as glow plugs not coming on first thing in morning if glow plug light comes on it will start with half a turn.
    Jan 2012
    Gloucestershire
    You should wait to hear from someone who knows this engine better than me, but I would guess at the crankshaft sensor. On the 1.9cdti at least, this can show signs of early failure only when the engine is warm, due to an electrical fault I believe.
    Don't take my word for it though, someone else will know more...
    Good luck!
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    9 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Agree.
    Diesels only need current to power the starter (and the injection, of course). Glow plugs should even be useless when the engine is hot...
    But there may be some electrical failure somewhere. The best to do is having the car diagnosed (Tech2 at the garage, or Vaux-Com if someone can lend one).
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Z80 View Post
    Why? The physics behind this is..... The only thing that differs electrically between the two is the one is ignited via a spark (petrol) the other is ignition due to compression (deisel). The starters are the same on both.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    indeed you are so correct.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Was there not an ECU software update for poor warm starting on the DTi's?
    ---Sent from my iPhone 4 using Forum Runner.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Yes there was an update it altered the glow plug timings slightly, check my threads regarding poor starting from warm
    My guess is even if you think battery is good replace it for a brand new one first then if it's no better replace starter motor
    Irmscher Insignia CDTI 130
    Apr 2008
    Noumea
    9 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Quote Originally Posted by GazCDTI150 View Post
    I mean that 1) the higher compression level on diesels calls for a stronger starter and a stronger (and healthy) battery, and 2) It only needs current then, as diesel engines burn without any electricity needed, or just a very small amount left to power the ECU and injector, but not so much, considering I could always have mine jump started and drive to a station to buy a battery, or to a garage when it was something else, such as the alternator (rewired) or damper pulley, and this with an almost completely empty battery. On the same DTi engine, BTW.
    As a consequence, and provided the glow plugs are only needed in cold weather (and cold engine), and considering the weather isn't cold right now where you live and it was stated the engine was hot, the problem can barely be related to the glow plugs.
    On the other hand, if it was a problem with the starter, it would be even worse when the car is cold, and he said he only has the problem when it's hot.
    Unless maybe there's something wrong with the coil, after all. Now a dying battery may also behave worse when hot...
    But the fact it happens when the engine is hot calls first for engine or electronics related problems.
    I would really have the car diagnosed first (actually, I'd do it myself with the Op-Cop).
    Now thinking about it, maybe the glow plugs are still needed to help the fuel start burning, as they maybe heat it much more than I may think. After all, we do change them here, despite hot outside temperatures.
    The fact that the dashboard indicator isn't showing when the problem occurs may mean some defective sensor fools the ECU in thinking the fuel is hot enough, or maybe a faulty glow plug may short-circuit when the engine is hot...
    But I wouldn't probably just replace the glow plugs, maybe for nothing, before performing a diagnostic.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Read the post after the one you quoted instead of the usual long winded explanation. But generally as current in a motor provides more of the 'force' needed due to the high compression of diesels. I would have thought a healthy battery would be needed on any engine for starting as that is when the electrical system is put under quite a bit of strain.
    Aug 2012
    Forget glowplugs and replace Crank Sensor as first port of call as said on post number 2
  1. Must push Accelerator when car is warm to start. Why??
    By Tank988 in forum Engine & Drivetrain
    Last Post: 8th November 2012, 00:33
  2. Vectra 2.0 DTi difficult to start when warm
    By C470 in forum Engine & Drivetrain
    Last Post: 11th July 2012, 16:35
  3. 2.0 turbo warm start problem
    By pipamish in forum Engine & Drivetrain
    Last Post: 25th March 2012, 21:59
  4. Vectra wont start when warm!
    By haye5 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 17:29
  5. 2.2 Direct warm engine start
    By Sambor in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:12
vectra hard to start cdti list of possible faults
2.0 dti difficult to start when warm
warm start problem 2.0 dti
Vauxhall vectra 2.0dti hard to start when warm
opel cdti hard start
vectra cdti warm start
vauxhall zafira 1.9 diesel starting problems
opel diesel difficult start
opel zafira b hot start
vectra c hard starting when warm
my vectra has trouble starting when warm
vectra 2004 deisel hard to start
vectra 2.2 difficult to start when warm
vauxhall vectra diesel starting problems
vectra dti warm restart
astra 1.9 cdti hard to start
vauxhall vectra 2007 cdti hard to start after warm up
vectra c 1.9 cdti hard to start first thing on a warm day
vauxhall omega poor starting when hot
2.2 dti warm start
opel 2.2 dti warm engine starting problem
vectra 1.9 cdti difficult to start
dti hard starting when warm
vauxhall vectra diesel hard to start when warm
vectra c poor warm start
