Thread: Here we go again
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    Default Here we go again
    Finally got my 2.2dti running tidy (well for a month)
    sat at traffic lights today everything fine went to pull off and the spanner light comes on with a total loss of power worse than when it used to come on. Restarted engine light was off and back to full power.
    the following codes came up
    P0340 camshaft position sensor circuit malfunction
    p0335 crankshaft sensor circuit range/performance
    B3794 cruise control switch circuit malfunction
    is there any way of cleaning these or will both sensors need changing?
    also where are these sensors located and are they just a case of unplugging the old ones and plugging the new ones in?
    Thanks in advance
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    crank sensor is on the front of the engine , low down at the gearbox end , replace this & hope the cam sensor fault stays off as this is part of the fuel pump .
    Aug 2012
    check the wiring harness for shorts and wear too
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    cleared the codes and its been fine for a week but tonight it just died on me
    restarted it sounded like a tractor with no power cut out again left it for five
    minutes and it started light out and drove like a dream
    showed cam position sensor crankshaft sensor and now its showing up
    p0149 injection timing control circuit malfunction
    could this be linked to the crank sensor?
    also read a thread in here saying my engine doesnt have a cam sensor is that right?
    Nov 2009
    newcastle
    If cranksensor knackered it kills the fuel system n won't start when I had bother. Diagnostic said fine on mine and correct info reading. Swopped it and started
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    when it was playing up it would turn for ages but not start also it wouldnt bump start
    hopefully i will change it and all will be ok
    Jun 2009
    durham
    Definatey try a crank sensor. Only about £20 and good access as its on the front. Mine developed a similar fault. I was convinced to nearly pay out for a fuel pump.... Glad I didn't and tried a sensor first!
    Nov 2009
    newcastle
    Mine would turn over and would only start with a start spray but wouldn't keep running. Sounds like u know what u need to do. Only wish my garage checked this earlier before they checked injectors and strip pumps down to check.
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    just ordered one £18 fingers crossed
    Aug 2012
    cardiff
    did it fix the problem
