Thread: Sound deadening rear doors
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Sound deadening rear doors
    Hi everyone,
    I'm trying to sound deaden my rear doors to improve the bass of my new alpine speakers. I put in the sound deaden sheet behind the speaker and around the speaker mounting, where else i can install it as its still rattling and sound awful when it hits powerful bass. Would i need to fill in the gap behind the plastic film.
    Cheers.
    emec#7
    Regular Member Bethan39's Avatar
    South Wales
    I'm glad you asked this as i have the same Alpine speakers in the rear doors as well, and they really rattle like crazy not tried sound deading yet as i was unsure where was best to start? i take it yours are amplified as well?
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    If it was me I'd sound deaden the full door to eliminate any rattles as the bass from the speaker will travel through the door.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my front drivers oem speaker rattles make sure theirs no shrapnel inside the door.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    As already said you will need to soundeaden the inside off the doorskin and the door pannel (what the doorcard fits to). I only had to soundeaden the door pannel as i build speaker pods to the doorcard itself, so the bass cant go passed the door pannel as it fully deaden with no holes.
    Regular Member Keif's Avatar
    In the Garage
    Remove the clear plastic, and the speaker. (hoover out any stones debris etc from inside the door)
    If you can, get some lining wallpaper and make a template roughly the same size as the clear plastic.
    Noting were all the plastic fittings locate, (You can use the same template for both sides)
    Cut some sound deadening to the size of the template.
    Working from the top of the door down, slowly fit the sound deadening to the door, you may need to warm it to follow the contours etc.
    Feed through the inner door release cable etc.
    Once fitted, you can cut the sound deadening around the speaker aperture and refit the speaker.
    Refit the door card
    One of the biggest causes of a rattle on the doors is the felt around the lock/unlock button falls out of it's location, with out it, the button rattles inside the top of the door card.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by Bethan39 View Post
    Yeah i'm using the alpine fx35 amplifier and had to turn down the gain and bass to the rears as it was rattling like crazy. It was absolutely awful.
    emec#7
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Thanks everyone, i give it a shot.
    emec#7
  1. sound deadening
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2011, 14:50
  2. Best sound deadening?
    By X-men in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 16:02
  3. Sound deadening, N/s done
    By mickydoos in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2010, 09:41
  4. Sound Deadening
    By storey_3000 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2006, 20:02
vectra c rear powerful hit noise on hole
