Results 1 to 10 of 13
Thread: Which New Battery from EuroCarParts?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Question Which New Battery from EuroCarParts?
    Hi folks. I'm after a new car battery, put my reg in eurocarparts & I get soo many results. Which one do I go for? They all have these different numbers & stuff on them, but which one is the best? I want one as powerful as possible as I've always got my sub on loud when I'm driving. Any advice much appreciated.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Bump
    West
    I swapped mine for a bosch s5 at the begining of the year, can't fault it
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    if you use eurocar pasrts use the code aoccom25 for 25% off unless they have a better deal on at the moment
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Thanks guys. I want the most powerful battery available!! Lol.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    hey guys. i ended up buying this one because it had the highest values eg 64ah 640a 12v Exide Premium.
    http://www.eurocarparts.com/ecp/c/Va...1578f59&000020
    and thanks for the code mate. came in well handy! well appreciated!
    PaZ!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I got a 72 Ah Exide from euro car parts, think its listed under the v6 cdti.
    Sent from my Nexus 7 using Forum Runner
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    the battery i bought is the highest listed for my reg number. i just checked my current battery, it says 66ah and 300a, so will the one i got cause any problems??
    Carnoustie
    Is it the same size as the old one?
    thanks Ronnie
    Nov 2009
    Bristol
    Ah is the discharge rate, this has no real relation as to how 'powerful' the battery is, it only gives an indication of how long it would take to fully discharge the battery.
    When buying a replacement battery it's more important to look at the CCA (Cold Cranking Amps) and CA (Cranking Amps) ratings. These ratings give a clear indication of how much current will be available when attempting to start the engine and the length of time the battery can sustain that level of current before battery voltage drops below 7.2 volts.
    So basically the higher the cranking amps rating, the more 'power' you'll have available to crank the engine and start it, however if you have an engine that doesn't want to start very easily then you'd need to know the current draw on the battery during cranking (an Amps clamp is the easiest way to measure this) and then compare that current draw to the Ah rating of the battery. This will give you some indication of how long you can keep cranking the engine over before the battery 'goes flat' and needs to be recharged.
    Personally I would look for a battery with a CCA rating in the region of 700A and an Ah rating of at least 70Ah that matches the dimensions of the original battery. From my experience, Varta Blue batteries are very good for the money (click) or if you want something a little more powerful the Varta Silver (click) is a very good choice.
  1. eurocarparts weekend code
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2011, 21:47
  2. eurocarparts 30% off
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 22nd June 2011, 17:54
  3. New Eurocarparts discount code...
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 16:16
  4. About brake disc from eurocarparts
    By qianjizhao in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 16:22
  5. Eurocarparts.............
    By ziplex in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 18:03
