Thread: starting problems
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default starting problems
    hi all,
    just recently, the old 2.2 dti is giving me trouble starting on a morning. it just keeps turning and turning and then it splutters into life with a nice cloud of smoke and then she's pretty much ok for the rest of the day.
    id say iv got a leak in the diesel run somewhere but i dont know where to look and im absolutely bogged down at work and havnt got the time to search, so id appreciate any quick answers that i can get.
    thanks in advance
    al.
    Nov 2010
    East Midlands
    Trim : design
    Have you checked your glowplugs?
    West
    Is the glow plug light comming on 1st thing?
    If you are getting the spanner for a minute or so after 1st start of the day then i'd suggest glow plugs, if not... have the battery tested, try unplugging the temperature sensor before starting see if this helps as well.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Glow plugs are fine as is the battery. I was thinking it maybe a leak causing the diesel to flow back?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    I'm actually talking about it cranking to the point of it almost flattening the battery before it splutters into life.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If the glow plugs are ok then the next point of call would be the leak off pipes and t pieces
    West
    Check the leak off pipes, they do become brittle over time
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Well, the b*****d things been starting up like a dream so I guess iv got an intermittent fault.
    I will change the leak off pipes anyway to rule that out. Is there a how 2 on this job at all?
    al.
  1. starting problems
    By beat275 in forum Engine & Drivetrain
    Last Post: 19th February 2013, 19:41
  2. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  3. Starting problems
    By Venom1924 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 23:55
  4. 2.0 dti starting problems
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 11th October 2011, 18:47
  5. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
