Thread: Non starter- ecu fried??
    Nov 2009
    newcastle
    confused Non starter- ecu fried??
    Wondering if any ideas
    Vec c estate 05 1.9 8v 120
    My car was put in a local garage to do the starter motor as I coldnt get the last bolt off underneath.
    Aa man had to start the car in the morning due to duff starter(had part already)
    Took down the garage myself. Car started several times over an hour to move in out of way in the car park.
    They done the starter and now it won't start.
    No error codes, all pumps, sensors injectors and leaks checked.
    Only fault that is found is fuel pressure is lost at the rail once primed. But both pumps and all sensors fine.
    Car will fire up with cold start style spray but lack of fuel getting to injectors.
    Im wondering if they didn't take battery off when doing starter and knocked a loose live wire against something and shorting the ecu. Especially after everything working and no error codes especially when there should be at least a few errors due to no pressure?
    Any ideas?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Not sure 100% what is involved but have they reconnected the plug at the steering pump? If they have failed this can cause bad/failure to start. Like I say whether this would have been necessary in replacing the starter motor I am uncertain.
    Nov 2009
    newcastle
    Il ask them but think they have rechecked all plugs. Steering Pump not in the way of the starter so doubt will be that. Hope urs that simple but after ruling pretty much everything out in my mind leaves only that
    West
    I've heard badly / incorrectly fitted earth connections can cause this, always best to double check
    Nov 2009
    newcastle
    I'm ask them but if this was case it shouldn't turn over and start with a cold start spray when it does?They reloading software this afternoon so I'm hopping it will sort but not that positive unfortunatly
  1. HELP!!!!! Head Fried
    By BBMadness in forum General Motoring Chat
    Last Post: 7th May 2012, 23:07
  2. I think I have fried it but you never know
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2012, 22:12
  3. Ethernet adapter fried
    By bigmac in forum General Chat
    Last Post: 14th April 2011, 09:22
  4. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  5. Expensive Fried chicken
    By MLC in forum General Chat
    Last Post: 9th April 2006, 14:36
