Thread: Signum drivers window issue
    Nov 2009
    Bristol
    Default Signum drivers window issue
    Hi all, I'm in need of some pointers and hope someone can help.
    I've a 53 plate Sigum Elite that has developed an issue with the drivers window. The window goes down fine but often won't go back up, sometimes when the window is halfway and I attempt to close it, it opens fully.
    There's no issue with the switch as I can hear the relay in the DDM clicking when the switch is pressed and also the RHR window can be operated perfectly fine when the rear windows are selected. I currently have the door card off and have done the old wiggle test on the wire harness to rule out any broken wires being the cause, but this has not identified anything obvious. I have however (due to extreme circumstances) found that banging the DDM several time whilst operating the up button will suddenly fire the motor into life and close the window.
    I'm assuming this is most likely being caused by a faulty relay inside the DDM, as a motor fault would likely also give some problems opening the window? So I'm just wondering if this is a common fault and whether there is a DIY fix, or will I have to replace the DDM? If so will a replacement DDM need to be programmed to the car and can I program this myself or is it a dealer only job?
    I'm not really a Vauxhall person, my background is with Japanese vehicles so any assistance would be greatly appreciated.
    Nov 2009
    Bristol
    Just realised I posted this in the 'Modifying' and not the 'Troubleshooting' section, sorry Mod's can you please move this thread for me. Many thanks.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    Nov 2009
    Bristol
    Quote Originally Posted by bigmac View Post
    Moved
    Many thanks!
    Nov 2009
    Bristol
    Anyone have any ideas before I strip the DDM apart? Could anyone point me in the direction of a pin-out or wiring diagram for the DDM to aid with bench testing it?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    try taking the switch apart and cleaning the contacts with nail varnish remover. no harm done.
    Regular Member kicker's Avatar
    Oct 2007
    West Midlands
    I'm sure there's a How to on this?? http://www.vectra-c.com/forum/showth...-Window-Switch
  1. Folding mirror / Passenger window issue
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 22:48
  2. Help - Drivers seatbelt issue
    By Vectra Forever in forum Bodywork & Interior
    Last Post: 30th April 2011, 19:39
  3. Electric window one-touch issue!!
    By Tyger in forum Bodywork & Interior
    Last Post: 9th February 2011, 20:18
  4. drivers window
    By garvey in forum Bodywork & Interior
    Last Post: 5th May 2008, 16:57
  5. Electric window issue ???
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2007, 21:25
signum drivers window
