Thread: Throttle Body help 1.8 16v (Z18XE)
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Default Throttle Body help 1.8 16v (Z18XE)
    Hi guys,
    I removed my throttle body today and gave it a good ol' clean.
    I ask because mine is completely blocked between the inner body and the metal tube (not the rubber tube itself). I know there is a tiny hole into the throttle but its seems blocked from that side too?
    Car runs fine but I'm wondering if I need to be concerned?
    I've looked everywhere but can find a simple diagram explaining what all the pipes are! (top are obviously coolant)
    Aug 2012
    engine vent hose. others are preheater hose apparently
    Apparently it can cause symptoms that can be attributed to the EGR
    http://zafiradiy.weebly.com/throttle-body-remove.html
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    How hard is it to remove mate? I've got an electrical malfunction on mine & it needs replacing.
    Aug 2009
    It's pretty easy.
    This guide is for an Astra but same engine so its works both ways
    http://www.astraownersclub.com/vb/sh...d.php?t=213566
    You'll need a few tools:
    Wide pliers - to undo the hoses
    Decent socket set - 7mm socket is for the intake pipe, to remove the throttle body's bolts its actually a E10 torx but a 6 or 7mm (iirc) socket will do.
    T27 or T30 torx - you'll need to remove the engine cover, the guide doesnt say so but you need to
    lots of rags
    carb cleaner
    Does look like I'll have to pull it off again to clear that blockage. Nothing would go through it lol
  1. Throttle body
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 17:32
  2. oil in throttle body help
    By drivs in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 19:13
  3. 1.8 Z18XE EML on (throttle error)
    By hig2k in forum Engine & Drivetrain
    Last Post: 3rd August 2010, 20:10
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
z18xe throttle body
z18xe oil on throttle body
vectra c z18xe trottle body
https:www.vectra-c.comforumshowthread.php171985-Throttle-Body-help-1-8-16v-(Z18XE)
throttle body heater hose vectra c
vectra thtottle body small holle mod
