Thread: soft brake pedal
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Default soft brake pedal
    Hi all. My car had to have new brake pipes installed and now I have sift brake pedal. It's all been bled 2 times and new master cylinder but still the same. Any idea?
    Dec 2011
    Seaham
    Still sounds like air in the system, take it back to the garage that did the pipes. Some people on here use an Ezibleed.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Right just an update for those how have or may have this problem some day. The brakes need bled with tech2. Set it to bleed brake and away you go. Hope this helps anyone.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    that is only usually necessary if the system has ran low enough to allow air into the ABS pump .
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    The front pipes were renewed so lost most of the fluid
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by beat275 View Post
    mm never seen the option to bleed brakes on tech2 lol, maybe something along the lines of activate ABS module which would help elimate the air from it?
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    That's the 1. Couldn't remember what it was called.
  2. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  3. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  4. New pads on front & back now soft pedal until 3 pumps
    By Deadrock in forum Suspension, Wheels & Brakes
    Last Post: 12th November 2010, 18:15
  5. New Pads now soft pedal
    By Clif in forum Suspension, Wheels & Brakes
    Last Post: 24th October 2010, 17:37
vectra c soft brake pedal
vectra c brake going soft
