Thread: Handbrake comes up too high
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Handbrake comes up too high
    My handbrake on the Signum is coming up to high, it hits the arm rest and pushes it up when fully on. I have changed the rear pads (were low) and reset the spring under the arm rest and it still comes up too high. Have I missed something or do I need to get a new handbrake cable next?
    Cheers for any help
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Did you press pedal to take up piston travel before touching handbrake
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    You can tighten the handbrake cable can't you?
    Regular Member Craig1985's Avatar
    harwich essex
    Sounds like time for a new cable.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by troutybrown View Post
    Not sure I did, can I take the rear handbrake cables back off and try it again?
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Dont need to take cables off, if you know how to reset the handbrake cable mech in the car, reset it with engine running pump footbrake a few times (do it quite quick) the pull up the handbrake and release a few times. If that dont help its time for a new handbrake cable.
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    I have the same problem after upgrading to 292mm discs and calipers on the rear. I have tried everything to try and fix the situation but I think the reality is that the handbrake cables are stretched. I can deliberately over adjust them using the self adjuster but it doesn't last long.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by cliomjh 102 View Post
    will try this in the morning and report back
  1. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  2. AutoGlym High Def Wax
    By andymagee1982 in forum Detailing and Car Care Discussion
    Last Post: 27th April 2010, 22:42
  3. Handbrake Lever high...
    By adamtaylor in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2010, 11:44
  4. High 5
    By Leviathan in forum The 'Off Topic' room
    Last Post: 17th February 2008, 02:06
  5. I think its sitting too high...
    By 2ltrT in forum Handling & Braking
    Last Post: 21st September 2006, 14:59
