Thread: 1.9cdti head gasket?
    Kent
    Default 1.9cdti head gasket?
    Hi
    not a Vectra but we have a Vivaro 1.9cdti which is loosing coolant, no oil in coolant and no brown sludge in the oil, I suspected head gasket but we filled it up with coolant didnt drive it for a week and checked levels and there was no coolant.
    I assumed if head gasket it would only leak with engine on and pressurised?
    No visible leaks and nothing on the floor
    Many Thanks for any input
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    if you've lost coolant whilst not driving it you must have a leak somewhere as it cant just dissapear
    Kent
    Thanks, so it can't be leaking internally if the engine isn't on? I assume the 1.9cdti engine is the same as the one in the vectra, it's not the 2700 model just a short wheel base model
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Bit of a difference I know but the wife's last punto was like this, turned out the water pump was the culprit.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    The engine in the vivaro is a Renault unit, rather than the fiat engine in the vectra.
    Get it pressure tested at a garage.
    Aug 2012
    Quote Originally Posted by XPCobra View Post
    There is a Fiat!!! Engine in my Vectra !!!!!!! WTF!!! Anyone wanna buy an SRI :-)
    I would remove the under engine tray (if it has one) and then park it somewhere flat. Fill it up and wait for the tell tale marks. If its only dripping slow then you may have to put some newspaper underneath - to show where the water dripped before it evaporated - and park it in a garage but you will get an idea of where the leak is if you do.
    Kent
    Thanks for all the advice, haha fiat engines in you vauxhall's what's in my fiat doblo van I wonder!
    Any idea of cost of pressure test, had new clutch , front brakes and oil leak fixed this year, don't want to throw much more money at it, if it's a couple hundred to fix ill do that before it goes on eBay, if not it goes on there as spares / repair I guess
    Dec 2010
    Glasgow
    Mileage : Near 100K
    About an hours labour, make sure it's tested at operating temp. Could be something as simple as an oil cooler that's leaking internally, Or a header tank with a pin hole in it (Had that before on a Renault)
    If it's the head gasket the van should blow out a lot of white smoke all the time.
  1. Head Gasket gone????
    By ussy2012 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 16:36
  2. 2.2 head gasket ???
    By mark_647 in forum Engine & Drivetrain
    Last Post: 23rd January 2009, 16:42
  3. 3.2 Head Gasket Gone/Going ??????
    By gsi32 in forum Engine & Drivetrain
    Last Post: 15th June 2008, 21:46
  4. head gasket???
    By coylo5 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2008, 23:04
  5. Head Gasket
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 17:28
07 1.9 cdti vauxhall vectra head gasket
vectra c 1.9 head gasket
vauxhall vectra 1.9 cdti head gasket l
1.9 cdti head gasket gone
