Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: cleaned dpf but now got no boost
    Jul 2010
    Nottingham
    Default cleaned dpf but now got no boost
    Hi all, I have 2006 sri 150 diesel, which recently broke down, spanner light on, and would not start full stop. Recovery man read codes stored and only on there was p2279 which he said was air intake system leak which he could not fix at road side, after looking at some forums for advice I cleaned the egr valve, boost pressure sensor, and checked all the vac and boost pipes all seem ok. I then removed the DPF filter and again following advice cleaned out all the soot and refitted. The car now starts up but there appears to be no boost, as there is a lack of power, there is also a kind of whistling/ humming sound coming from around the turbo unit which is audible from inside the car so is quite loud. If driven on the motorway spanner light comes on and the fault stored says p1901-75 Particulate sensor high differential pressure. Any advice on sorting this would be appreciated guys,
    Ps the car had no problems with boost, before I cleaned the dpf have I done something wrong maybe ???
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    sounds like the dpf is still blocked up and the engine is struggling to breathe..
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Dpf is fooked Mate had a Mazda with same problem today wiped it out software on out it went get it removed matey
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    As above, assuming you used a jetwash, theres prob a build up of water still in there mabe, im pretty sure that the honeycomb centre of a dpf has small passages that are alternately blocked so only draining it one way might trap some water in, just an idea mind, try letting it tick over for a bit it, it might burn off any residual water if any
    Jul 2010
    Nottingham
    Thanks for the replies guys, I did soak the dpf in alloy wheel cleaner overnight then used pressure washer until i could see no more crud come out of it, when I first ran it there was some steam coming fron the exhaust but that cleared up pretty quick, I have done about 200 miles since doing the dpf and all that time it drives like a non turbo car, would a blocked semi blocked dpf allow the car to start and run ok but not allow any boost ???
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Did you make sure you refitted the temp sensor and both pressure sensor pipes, if so i'd double check the two pressure sensor pipes/tubes as they can pop back off
    Jul 2010
    Nottingham
    Yes they are all fitted mate
    Regular Member C-Owner's Avatar
    May 2011
    South London
    There's no such thing as "cleaning" a dpf its impossible to do it correctly.
    Best options
    In order of recommendation.
    1. Completely remove the honeycomb re-fit the unit and get a remap with the dpf off.
    2. Get a dpf replacement straight through pipe made and have the sensor and pipe work removed and remap dpf off.
    3. Drill holes through the dpf re-fit the unit.
    4. Fit a new dpf.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    You could check your exhaust for any leaks working from your dpf all the way to the pre-cat because when a dpf cloggs it causes quite a bit of back pressure and possibly found a weakness in your exhaust somwhere at the front, as you said you got some loud noises coming from that area, have you noticed any fumes smell from that area when engine is on?
    Jul 2010
    Nottingham
    I have checked for leaks and there is none, however I have been searching this forum for possible answers and found one which said if I remove the vac hose off the solenoid on the slam panel to see if the noise dissapears, did this and noise did dissapear, not sure what that means as there was no answer to the rest of the blog ?? still confused, thanks for the replies guys
  1. One cleaned Boost Sensor......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 20th August 2012, 00:22
  2. Just cleaned my boost sensor
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2011, 19:43
  3. Just cleaned my egr and boost sensor !!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 17:32
  4. egr/boost cleaned
    By tomo610 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:19
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
