Thread: CDC40 to CDC40 MP3 upgrade.... any advice?
    Jun 2012
    Ireland
    Default CDC40 to CDC40 MP3 upgrade.... any advice?
    Hi all,
    I'm a newbie and I need some advice.
    I have a 07 Vectra 1.9CDTi Estate - Love it!
    I would like to replace the CDC40 Opera unit with the MP3 version and I'm curious as to whether it's possible and if so, what's involved.
    For instance, will the existing display unit work with the MP3 version?
    Is this a straight swap - i.e. are the cables / connectors the same?
    I know that the unit itself will have to be 'unlocked' (divorced?) but I don't think this looks too difficult. It's the other issues that concern me.
    I would really appreciate any help on this.
    Thanks in advance.
    Best regards,
    Eamon.
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    This has been asked many times. I'm not aware that there is a CDC40 MP3. There is an CD30 and a CD30 MP3, as least I think that is correct.
    Basically the aux input to the CDC40 is used by the DAB unit. The DAB unit is below the Glove Box.
    To get an Aux -in you would need to switch to the DAB tuner, then interupt the Left and Right audio signal input to the CDC40 and substitute the MP3 input instead.
    This could be done by using a switched 3.5mm stereo headphone socket.
    I'm not sure that anyone has actually done this and got it working.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Im sure some cdc40's take MP3 disks
    Jun 2012
    Ireland
    Thanks Tony and Mark for your help.
    @Tony - I'd prefer to avoid the iPod In route if possible. I've had CD MP3 in my last few cars and I found it very convenient - easier (and safer) to read on the road etc.
    In fact, given the choice of an autochanger or MP3 CD, I would go for the latter. So, I'm not really that concerned about the changer - I would be quite happy with a single MP3 CD player (is that the CD30?) so long as the quality was reasonable and it was an uncomplicated swap.
    @Mark, I have discovered that the Grundig CDC40 will play MP3 CDs but the (earlier?) Blaupunkt CDC40 will not. Unfortunately, mine is the Blaupunkt. I think another distinguishing factor is that the unit eith has DAB or MP3 but not both. As it happens, I'm not bothered about DAB. So if anyone in the opposite situation wants to do a straight swap, that would be great
    Thanks again folks.
    Best regards,
    Eamon.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Just get a parrot MKi9200, solves all your problems with MP3's and gives you bluetooth phone connection as well
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    I looked on EPC4, and it describes all CDC40's as CD40 MP3.
    None were listed as non-MP3 - so your's SHOULD play MP3's burnt onto CD's.
    However the software used to burn the CD's can make all the difference.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I tried playing MP3s on the CDC40 that I used to have, didn't work. The CD70 does play MP3s and even though it's only a single disk you can still put loads of songs on the disk (normally 6-7 albums)
  1. CDC40 DAB upgrade & I have some Q's...
    By Neve'o in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2012, 16:46
  2. CD30 to CDC40 Upgrade?
    By DuncanM2009 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2011, 21:33
  3. Upgrade from cdc40 to cd70
    By jhinchy in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2011, 09:09
  4. CDC40 Upgrade
    By snod in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2008, 23:12
  5. Cdc40 + Mp3
    By Legless in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2007, 21:40
cdc40 opera replace dab with mp3
blaupunkt cdc 40 mp3
