Thread: Oil/spanner light
    Aug 2012
    South Wales
    Default Oil/spanner light
    Can anyone tell me if this is normal when I start the car the oil spanner light comes on give it a small rev and goes out same when I switch off its cdti sri150
    Aug 2012
    South Wales
    Anybody ?
    11 Post(s)
    Oil/spanner light!
    Do you mean the car/spanner light?
    Aug 2012
    South Wales
    No it a oil can with spanner through it
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    oil can normally means servicing time
    Aug 2012
    South Wales
    I just give it a service is there a way to reset it workout a reader
    West
    There's away to reset & it's in the how to section
    11 Post(s)
    Quote Originally Posted by Mike1975 View Post
    Sorry, was looking in a newer handbook. Forgot the older Vec-C's had an oilcan and spanner symbol for a service light.
    Does it also display some numbers underneath?
    To reset the service light, it's something like:-sit in the car, hold down the odometer reset button and turn the ignition key to posn 2.. do not let go of the reset button until the display changes.. about 10 to 30 seconds..
    the display will then change to the reset mileage..
    On some of the newer Vauxhalls this won't work. You have to press the trip reset button on the dash and also press the brake pedal as well before switching on the ignition - keep brake and trip pressed for 10 to 12 seconds - then the service interval light will be reset.
    Aug 2012
    South Wales
    Well done the service reset and light went out but now got the car spanner light in start up wtf is up with my car
    11 Post(s)
    Providing the car/spanner light goes out as soon as the engine is running, then there is nothing to worry about.
    If it stays on until the engine is running, it's just indicating a stored fault code.
    Being a diesel, it could be an early warning sign of failing glow plug(s)
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
How to delete oil can and spanner light Vectra c
vauxhall vectra oil light with spanner warning intera light comes on
vectra c 2.0 dti spanner light reset
vauxhall vectra engine oil light with spanner
reset oil service light vectra c
