Anyone got any tech data on this ??
the cam pulleys have no keyways to locate them and Autodata online has ****** all info unless your only changing the belt !!
Cheers Andy
Cheers Andy
Problem solved !!
Anyone doing your vvt pulleys you need AST4995 tool
Can I ask why you removed the cam pulleys? Do you not just slacken the tensioner to remove the belt?
I replaced the knackered vvt pulleys , engine code was Z18 not X18 if that what threw you !!
dont forget to take the rocker cover off and to use a flat piece of 4.5 mm metal to lock both the cams at the right hand side of the engine....
That's in the AST4995 kit !!
I didn't know that Andy, I made my own and bought the 2 piece cam
pulley locking tool.
Easy enough to do, the Hynes manual describes how to do it.
