Thread: X18XER cam setting after renewing belt and vvt pulleys
    Feb 2012
    Yorkshire
    Default X18XER cam setting after renewing belt and vvt pulleys
    Anyone got any tech data on this ??
    the cam pulleys have no keyways to locate them and Autodata online has ****** all info unless your only changing the belt !!
    Cheers Andy
    Feb 2012
    Yorkshire
    Problem solved !!
    Anyone doing your vvt pulleys you need AST4995 tool
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Can I ask why you removed the cam pulleys? Do you not just slacken the tensioner to remove the belt?
    Feb 2012
    Yorkshire
    I replaced the knackered vvt pulleys , engine code was Z18 not X18 if that what threw you !!
    Mar 2011
    belfast
    dont forget to take the rocker cover off and to use a flat piece of 4.5 mm metal to lock both the cams at the right hand side of the engine....
    Feb 2012
    Yorkshire
    That's in the AST4995 kit !!
    Mar 2011
    belfast
    I didn't know that Andy, I made my own and bought the 2 piece cam
    pulley locking tool.
    Easy enough to do, the Hynes manual describes how to do it.
  1. Drive belt, pulleys and tensioner replacement
    By no1vic in forum Engine & Drivetrain
    Last Post: 13th November 2016, 20:41
  2. Rear Seat belt - Torque setting
    By Dane-10 in forum Bodywork & Interior
    Last Post: 12th January 2013, 19:36
  3. wyning pulleys
    By djdee in forum Engine & Drivetrain
    Last Post: 9th July 2011, 12:09
  4. access to pulleys?
    By neill in forum Engine & Drivetrain
    Last Post: 5th September 2010, 18:29
  5. New pulleys?
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 09:49
vauxhall vvt pulley how to change
how to change vauxhall vvt cam pulleys
