Thread: Touching up
    Regular Member Max Payne's Avatar
    Sep 2012
    OXFORDSHIRE
    Default Touching up
    Got a small area of paint missing right on the edge of the drivers door, so i've bought a vauxhall touch up kit paint and clearcoat. I've noticed that a small part is right down to the metal, should i use a primer first as the vauxhall kit on the back just mentions cleaning off any rust then applying base coat. As there isn't any rust is this wise or should i still use a little grey primer which i still have from my old halfords kit from previous vectra c ? Want to get it sorted before the bad weather arrives. Not had this one long it's a 58 plate 1.8vvt 16v sri in sapphire black only got 19,700 miles on it so want to look after this one as my old car was kindly written off this summer by some idiot whilst on holiday.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    You need to use an acid etch primer on the bare metal
    Sep 2012
    OXFORDSHIRE
    Halfords pen just says grey primer filler ?
    Sep 2012
    OXFORDSHIRE
    Upol acid 8 etch primer from halfords ? Spray can though, guess you could spray into lid and use small brush or cocktail stick ?
  1. Replies: 42
    Last Post: 23rd June 2008, 11:48
  2. New method for touching up
    By Penfold in forum Detailing and Car Care Discussion
    Last Post: 5th October 2007, 18:15
