Results 1 to 10 of 25
Thread: Replacing brake disks
    Sep 2012
    Surrey
    Question Replacing brake disks
    Hello fellow vectra-c-ers,
    I need to change the brakes on my 53 reg Vectra C. Got all parts ready. Yesterday started the work: took the wheel off, easily undid the caliper and got the pads off. Now I needed to undo the two torx bolts to release the disk - but that's where I got stuck. I know these are usually done up very tights and have threadlocks on them. As I didn't have E20, I tried different sockets (1/2", 12mm and 13 mm) to no avail. The corners on the bolt started rounding up - don't want to mess it up completely. I tried WD40 on them, but even that didn't help.
    I ended up putting everything back together, as needed the car this morning. I ordered the E20 socket - should arrive tomorrow hopefully.
    In the mean time, any other ideas how to undo these bolts?
    Many thanks in advance!
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    wait for the correct socket unless you intend to replace the bolts
    bit of heat normally helps
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    A long breaker bar will help you exert more torque on them when initially breaking the seal on them too.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    I have an E20 socket here if you want, i am in Knaphill best bet is to use a breaker bar to crack off the bolts as there usually done up with locktite
    Sep 2012
    Surrey
    Default Long breaker bar
    Yeah, thanks, that would be the obvious thing to do. Unfortunately, there's not much room for a very long bar around there. I don't have a facility to raise the car, so have to do withe jacking it up. I am already using a pipe extension on the handle. Hopefully it will be better with the right socket.
    I am also thinking about loctite freeze and release spray or plusgas spray. Anyone tried it?
    South east
    Make sure the E20 socket fits a 1/2" spanner/ratchet, not 3/8", or the bit that fits inside the head of the E20 will snap under the force.
    Sep 2012
    Surrey
    Quote Originally Posted by Rebellion View Post
    Yes, that's the one I got: 1/2" driver.
    Sep 2012
    Surrey
    Quote Originally Posted by bobssignum View Post
    Thanks a lot. I already ordered one and won't have time to do the job before it arrives, anyway.
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    It's a horrible job to do but a breaker bar as people have said. I tend to use the breaker bar to get it started as you really cannot turn the bolt too much due to the floor being in the way. Once it's moving, then on to a torque wrench.
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    If you were nearer you could have come here. I got mine nice and high (in a rather unconventional way) when doing mine which gave me plenty of leverage!
  1. brake disks
    By trickyjacks.4 in forum Handling & Braking
    Last Post: 15th February 2012, 15:44
  2. Yellow brake disks....
    By Rorschach in forum The 'Off Topic' room
    Last Post: 10th June 2011, 11:30
  3. Big brake disks going cheap
    By signum junkie in forum Parts for sale
    Last Post: 27th August 2008, 09:08
  4. OEM Brake disks + Pads
    By falco in forum Handling & Braking
    Last Post: 22nd January 2008, 18:09
  5. corsa brake disks
    By jonno_07 in forum Handling & Braking
    Last Post: 16th September 2006, 08:21
