Thread: Air Conditioning Condensor
    Default Air Conditioning Condensor
    I Bought a vectra c est 1.9cdti sri 4 weeks ago, had the aircon regassed before i bought it as it wasnt blowing cold.
    Picked it up and was ice cold, after 3 weeks it stopped, had a guy come and look at it and he said it was the condensor and that would be £280 to fit it. He also said that there was a dye patch on the compressor but didnt know if that was kaputt until he had done the condensor and regassed.
    Phoned the garage up and the A/C isn't covered under warranty.
    Any ideas, the engine picks up in revs when the ac button is pressed and i can hear a faint whiring noise through the vents.
    Regards
    Regular Member Munkey's Avatar
    Jun 2012
    United Kingdom
    Had the exact same thing a couple of months ago - mine was the compressor, which should be covered under a warranty as they are mechanical parts depending on the specifics of your warranty. Because the AC in my car hadn't been used properly (ie regularly) it packed up about 3 weeks after using it.
    However the condensor wont be covered as it can easily be damaged by a stone at any time - hope that helps.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Don't know how car savvy you are but there is a How 2 on replacing the condensor and it looks super easy, at least if you do that bit yourself its money saved even if you need the compressor doing too
    Jun 2012
    United Kingdom
    Can get them for about £80 - £200 bucks http://www.onlineautomotive.co.uk/Va...ondensers.aspx
  1. Air Con Condensor
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2011, 20:08
  2. Would You Say Condensor?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:41
  3. air con condensor
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 12:04
  4. Air-con condensor..
    By tonyo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 21:28
  5. Air Con Condensor Help!!
    By Jimooo in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 22:34
