Originally Posted by
06sri
mainly for acluter:
the way i see this, and yes it is simply different, but a 20 yr old house with 20 year s of gloss on its skirting boards, bits of carpet and all sorts stuck to it, paint runs galor, to fix this you would remove paint, sand it back add some primer then re paint.
the learning process here, is setting the gun correctly, mixing your paints and keeping things clean, and practice, dont go drowing it in paint, i do not for one minute think im gona uppack my compressor add the paint to a gun, spray and get a perfect results.
i will be practing first, setting gun up etc and using the cheapest paint i can find (need to make sure you use the same materials that you wil be spraying your bits eventually with) and have a practice.
