Results 1 to 10 of 14
Thread: Swirl actuator
    Regular Member carl78's Avatar
    Mar 2012
    Telford
    Default Swirl actuator
    Swirl actuator faulty would this affect performance? coz my cdti 150 with remap struggles to keep up with standard 22se so help plz
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by carl78 View Post
    I would say you defo have a performance issue as (without wanting to start a debate) a remapped CDTi 150 shouldn't have a problem with a 2.2.
    What remap do you have? Do you still have the EGR functioning? Is your swirl bar intact?
    Mar 2012
    Telford
    Cg remap mate and egr blanked off and deleted as well as the dpf. Swirl bar intact and still on so dont know where to go now. Just waiting to get codes read later to day if it comes up with egr i'll go back to mapper.
    Lancashire
    Trim : XP NAV
    Could be a boost leak; check hoses etc. Vacuum issue; lots of threads on it.
    Those are probably the best place to start.
    EDIT: Looking at your other posts, you have had issues with the DPF (even after getting it mapped out), could this still be causing issues?
    Mar 2012
    Telford
    I have replaced vac pipes with silicone ones. And i dont know about dpf coz no codes coming up for it
    Regular Member djnick's Avatar
    Jun 2012
    vectra-sport moderator
    your actuator is what turns the swirl bar its attached at swirl flap 3 position so if you have a faulty actuator it might not be doing its job of turning your swirl bar and opening and closing the flaps which will give you a loss in power
    Mar 2012
    Telford
    I've seen the bar move freely so dont know mate
    Mar 2012
    Telford
    Right this is the story so far had codes read and guess what codes was p0400 EGR air flow which i paid mapper to have deleted along with dpf and more power but also had p2075 IMT cercuit bank 1? dont know that is but back to the mapper rang him and he says it's my car his map thats at fault and wont refund me for a so called map i dont have
    Jun 2012
    where did you get it mapped mate
    Mar 2012
    Telford
    cg remaps newport shropshire mate
  1. Swirl flap actuator
    By jofenan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 21:01
  2. Swirl pot actuator
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 21st November 2009, 01:00
  3. swirl actuator problem
    By ziggi in forum Engine & Drivetrain
    Last Post: 30th September 2009, 03:34
  4. swirl actuator problems
    By ziggi in forum Diesel Engine related
    Last Post: 28th August 2009, 11:47
  5. swirl valve actuator
    By wirrallad in forum Engine & Drivetrain
    Last Post: 4th August 2009, 19:54
signum cdti 150 p2075 site:www.vectra-c.com
